Page 1 of 4 123 ... LastLast
Results 1 to 25 of 76
Thread: Brake Options for the Mazda 3
    Oct 2005
    Default Brake Options for the Mazda 3
    Folks ... In my quest to find Brake Pads / Rotors for AutoCross (Solo-2 and lapping), I came to the conclusion that there was not alot of options (At least by Honda Standards) sooo to keep everything straight I put together this list for myself ...and I thought I would share it.
    Keep in mind this is NOT the definitive list nor is it 100% accurate ...So this is where you guys come in ...if you notice a mistake, or know of other options, can you post it up and I will update this list.
    The Part numbers are as accurate as I could make them HOWEVER there may be typo\'s / mistakes so PLEASE do not order by these numbers alone ...please confirm the application if and when you place an order
    I broke down the Brake pad options into four ROUGH types of pad to help determine what type of pad you might want. I do suggest that you reasearch the pads further to determine the compound that you might need/want. Each type of pad comes with its own set of positives and negatives, and comprimises.
    Mazda 3 Brake Options (US and Canadian vehicles)
    Rotors for 2.0L car 278mm (f) 265mm(r)
    EBC (f) D1312
    EBC (r) D1314
    Brembo (f) 25875 (Not shipping yet)
    Brembo (r) 25873 (Not shipping yet)
    Raybestos (f) 980295
    Rotora (f&r)(Slotted)
    Rotora (f&r)(Slotted and drilled)
    KVR (f&r) (Drilled)
    Centric (ProPartsUSA) (f)
    Centric (ProPartsUSA) (f)Sloted
    Centric (ProPartsUSA) (r)
    Rotors for 2.3L car 300mm (f) 280mm(r)
    EBC (f) D1313
    EBC (r) D1315
    Brembo (f) 25876 (Not shipping yet)
    Brembo (r) 25874 (Not shipping yet)
    RacingBrake.com (f) 9022-111 (Slotted)
    RacingBrake.com (r) 9023-111 (Slotted)
    SR Motorsports upgrade kit (f&r) (Slotted and Drilled)
    KVR (f&r) (Drilled)
    OE Replacement Pads Front
    -Satisfied PR-1044 Pro Perform
    -Wagner PD-1044
    -Raybestos PGD-1044C (Ceramic)
    -Duralast MKD-1044 Semi Metalic
    -Duralast Gold DG-1044 Semi Metalic
    -Morse Ceramic 1044C
    -ACDELCO Durastop 17D1044C
    -SP Performance MD-1044
    -Mintex MDB2634
    -PBR Deluxe Plus D1059DP
    -PBR XBG M/Master D1059M
    Performance Street Pads Front
    -Satisfied PR-1044C Pro Ceramic
    -EBC DP-21524 (Green)
    -Akebono ProACT Ceramic
    -Hawk HB519F.682 HPS
    -SR Motorsports M3-14133front
    -Rotora RP.10440.01 - H2 Ceramic Brake Pads
    -PBR ULX Ceramic D1059C
    Street / Track / Autocross / HDPE Pads Front
    -Porterfield AP-1044 R4-S
    -Carbotech CT1044 Bobcat
    -Carbotech CT1044 Panther Plus
    -OMP OT-8020
    -GrandSport(Satified) GS-5
    Track Only Pads Front
    -Porterfield AP-1044 R4 (Full Race)
    -Porterfield AP-1044 R4-E (Endurance Race)
    -Porterfield AP-1044 R4-I (Full race with quicker warm up)
    -Carbotech CT1044 Panther XP8
    -Carbotech CT1044 Panther XP9
    -Carbotech CT1044 Panther XP10
    -GrandSport(Satified) GS-4, GS-3
    OE Replacement Pads Rear
    -Satisfied PR-973 Pro Perform
    -Wagner MX-973A
    -Raybestos PGD-973M
    -SP Performance MD-973
    -Bendix MKD973 Semi-Metallic
    -Mintex MDB2281
    -PBR Deluxe Plus D1067DP
    -PBR XBG M/Master D1067M
    Performance Street Pads Rear
    -EBC DP-21354 Green
    -Axis Metal Master 108.09730
    -Axis Ultimate 109.09730 Ceramic
    -SR Motorsports M3-14133Rear
    -Hawk HB478F.605 - HPS Brake Pads
    -PBR ULX Ceramic D1067C
    Street / Track / Autocross / HDPE Pads Rear
    -Porterfield AP-973 R4-S
    -OMP OT-7983
    -GrandSport(Satified) GS-6
    Track Only Pads Rear
    -Porterfield AP-973 R4-E
    -Porterfield AP-973 R4-I
    Big Brake Kits ...Not that you really need it
    -TCE Performance products
    Front 13\" kit with 4 piston calipers
    Rear 11.75\" kit with OE calipers
    -Rotora
    Brake Lines (Stainless)
    -TechnaFit
    -SR Motorsports
    -CorkSport
    Sr Member bluntman's Avatar
    Apr 2004
    Default Replying to Topic \'Brake Options for the Mazda 3\'
    Smells like a sticky.
    flickr
    "boom goes the dynamite"
    Oct 2005
    Ahhhhhhhhhh I feel so special
    Rear Pads- Hawk HB478F.605 - HPS Brake Pads
    Front Pads- Rotora RP.10440.01 - H2 Ceramic Brake Pads
    Oct 2005
    Added to the list
    Moose
    Oct 2005
    Added PBR/Axis Front and Rear Pads (three flavours of each) to the list
    The Ultimates/Ceramics were VERY good when I used them on my Civic .... Similar to the Hawk HP+ compound ...
    Moose
    Oct 2005
    Update
    I just talked to my Wholesale contact about Grandsport pads ... they are now avaiable in GS-3, GS-4, GS-5, GS-6(rear)
    The GS-5 should perform as well as Hawk HP+ and the GS-3 Should perform as well as the Hawk Blues ... Very good pads for the money
    I have ordered a set of front GS-5\'s and a Set of Gs-3\'s for track days. I will be ordering a set of the Either the GS-6\'s or PBR Ceramic for the rears to match the front setup.
    Cheers
    Moose
    Jul 2004
    I have a set of Hawk HP+ on order. The EBC Greens I have now are adequate for street driving but are rather susceptible to fading on the track, maybe even more so than the stock pads.
    I\'ll get the part numbers when they come in. Good info btw.
    Oct 2005
    Hmmm .... I did not think that the Hawks came in a HP+ ...only the HPS. When did they become available ????
    Moose
    Jul 2004
    Moose
    I\'m wasn\'t aware of it either, but apparently their Blue compound is also available. I\'ll update as soon as they arrive (ordered through Tires23).
    Sep 2004
    Any ideas when the Brembo discs will start shipping and where they will be available?
    Oct 2005
    Nope: I checked with the Canadian Importer/Distributor and they do not know as of yet ... I suspect by the end the year (2006) as it took almost a year for the Integra Type \"R\" rotors to be relesed in North America after they were realeased in Europe ...
    Moose
    Jul 2004
    Moose
    At long last...they\'re in.
    Hawk HP+ for Mazda3:
    HB519N.682
    KenYork
    Guest
    What\'s the price range for each of the 4 types?
    Oct 2005
    Each of the 4 types of what, the pads ???
    If you are refering to the Pads .... well the price is all over the place ... and the prices will vary by location / region
    I were to guesstamate the approximate price ranges this is what they would be ... but the only way to know is to get a quote from a retailer or do some searching arround the web
    OE Replacement $30-$75 a set
    Street Performance $75-125 a set
    High Performance Street / Track / HDPE $100-150 a set
    Track $150 +
    Rear paqds will generally be a bit cheaper .... but not allwyas
    Moose
    KenYork
    Guest
    Track $150 +
    Moose
    thanks. that\'s exactly what i\'m looking for.
    Sep 2004
    Any updates on the availability of Brembo rotors?
    KenYork
    Guest
    Are all the pads mentioned above for both the 2.3 and 2.0?
    Oct 2005
    Brembo Rotors - I have not heard anything yet
    Both the 2.0 and 2.3L cars use same pad ... just the rotors differ (11\" vs 11.8\")
    Moose
  20. The Following User Says Thank You to Moose For This Useful Post:
    Skippy (04-19-2014)
  21. #20
    Sponsor
    Sep 2005
    I need someone to make sure if the 2.0 and the 2.3 share the same pads. I\'m just about to order a set of front and rear Endless brake pads.
    2010 Subaru STI
    Mods:
    Not enough room to list
  22. #21
    Oct 2005
    Yes,
    The 2.0L and 2.3L car share the same front and rear pad part numbers
    I double checked three manufacturer web-pages
    Moose
  23. #22
    Sponsor
    Sep 2005
    One more question. Since brembo don\'t ship the 3 disc yet. Will any other mazda cars have the same size disc that we can use for the 3? ie. MPV, Mazda 6, protege, ?
  24. #23
    Oct 2005
    Not that I am aware of ... one would need access to the Mazda parts look up to cross reference the rotors
    Moose
  25. #24
    Oct 2005
    Ok ... the CDN distributor now lists Brembo blanks for the 3 ...I have a call into my contact to see what is going on ... availability, price etc.
    Moose
  26. #25
    Jr Member sbmonkey's Avatar
    Jun 2006
    EBC Red stuff is also now available for the 3:
    Front: DP31524
    Rear: DP31354
    nsnmotorsports.com has them for $63.10 and $53.10 (USD), respectively.
