Originally posted by Moose
High Performance Brake Fluid Comparison:
The Dry Boiling Point is the temperature at which a brake fluid will boil in its virgin non-contaminated state. The highest temperature Dry Boiling Point available in a DOT 3 fluid is 572 F
The Wet Boiling Point is the temperature a brake fluid will boil after it has been fully saturated with moisture. The DOT 3 requirement for wet boiling point is a minimum temperature of 284 F.
When fluid \"boils\" the fluid vapourises and causes gas pockets ... these gas pockets are compressible, brake fluid in liquid format does not compress. As a result of these gas pockets, you get a \"spongy\\\" pedal feel at best, at worst you have NO brakes. Basically when you press the pedal all you are doing is compressing the gas, not the fluid thus not the brakes pads against the rotors.
There are many ways for moisture to enter your brake system. Condensation from regular use, washing the vehicle and humidity are the most common, with little hope of prevention. Glycol based DOT 3 & 4 & 5.1 fluids are hygroscopic; they absorb brake system moisture, and over time the boiling point is gradually reduced.
If you bleed / flush your brakes religiously then the wet boiling point is less of an issue, as you are removing the water loaded fluid, but if you are like most of us who do not flush/bleed that often then a high wet boiling point fluid is important
Highest to lowest DRY --------Dry / Wet----Amount---List Price in USD
Project U G4-335---------------671 / 429-----1L--------$50.00
Neo Super DOT 610-------------610 / 421-----340ml-----$15.00
MOTUL RBF 600----------------594 / 421-----500ml-----$15.00
CASTROL SRF------------------590 / 518-----1L--------$70.00
AP-Super 600------------------590 / 410-----500ml-----$18.00
Pentosin Racing brake fluid------572 / 393-----1L--------$26.00
Willlwood 570-------------------570 / 284-----340ml-----$8.00
PFC Z-Rated-------------------550 / 284-----500ml-----$10.00
Ford HD------------------------550 / 284-----500ml-----$3.50
ATE Super Blue / Type 200------536 / 396-----1L--------$12.00
APE 551------------------------528 / 288-----500ml-----$12.50
Motul DOT 5.1------------------509 / 365-----500ml-----$6.50
Valvoline Synpower-------------503 / 343-----500ml-----$5.00
Castrol LMA--------------------446 / 311-----500ml-----$3.50
The Best Wet AND Dry perfomance vs Price, and the easiest to find is the Motul RBF 600 ... But if you can find the NEO then itis a good low-cost option.
Moose
