Results 1 to 17 of 17
Thread: A-Z of RIM INFORMATION
    Sr Member 3GFX's Avatar
    Jun 2006
    Default A-Z of RIM INFORMATION
    From 1010tires.com
    Offset
    The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
    To compare the effects of changing the offset and width of your wheels use the
    Wheel Offset Calculator
    Bolt Patterns
    Each wheel has a different bolt pattern, and some wheels even have 2 different bolt patterns which allow it to be mounted on a wider range of vehicles.
    Most Bolt Patterns are represented in the following manner:
    4/100
    • The "4" indicates the number of holes in the wheel for the bolts to enter and mount the wheel onto the car.
    • The "100" indicates the diameter of the bolt circle measured in millimeters or inches. 4 & 6 bolt wheels are measured from the center of one bolt hole to the center of the bolt hole directly across from it. On a 5 bolt pattern, it is a bit trickier to measure without special tools. Imagine a circle running through the centers of each bolt hole. You would measure from the center of one bolt hole to the imaginary circle that lays between the opposite two bolt holes.
    Plus Sizing
    Plus sizing your wheel & tire combination was designed to enhance vehicle performance and looks by allowing fitment of larger diameter rims and lower profile tires. The theory is that while making these changes, you keep the overall tire diameter within 3% of the original equipment tires. This is important because larger variances can cause problems with transmission shift points which can decrease fuel mileage. It can also confuse braking system computers which can even lead to brake failure.
    Here's the rule of thumb for "plus sizing":
    Plus 1:
    Increase section width by 10mm
    Decrease aspect ratio by 10 points
    Increase rim diameter by 1 inch
    Plus 2:
    Increase section width by 20mm
    Decrease aspect ratio by 20 points
    Increase rim diameter by 2 inches.
    This is not exact, but it will usually get you in the right ballpark. We always recommend consulting with the people you are purchasing the wheels and tires from to ensure fitment.
    For tire size comparisions try our Tire Size Calculator.
    Wheel Care
    It is important to keep your wheels clean at all times. Your brakes will cause the wheels to heat up, and this heat in turn can cause any dirt or brake dust to cook in to the clear coat. If this happens, there's not a lot you can do besides having the wheels refinished. Protect your investment and keep your wheels clean!
    Below are some simple instructions on how take care of your wheels:
    • Do not use household cleaners or other detergents to clean your wheels. The best wheel cleaning solution is a mild soap and water solution (what ever you would trust on the paint of your car). Clean with a soft, un-abrasive cloth. Only on polished wheels can you use aluminum wheel polish. If you use this polish on chrome, painted, or clear coated wheels, you will only scratch or dull the finish. </SPAN>
    • Do not use steam cleaners in automatic car washes.
    • Do not use any tire cleaners on your wheels.
    • Clean wheels when they are cool. Heat can effect the soap, causing it to dry on the wheel and become difficult to rinse off.
    • Clean one wheel at a time. This also prevents the soap from drying on to the wheel.
    • After the wheels are clean and dry, apply a coat of soft paste style wax to them. This will create a moisture barrier and help ensure the finish lasts as long as possible.
    > Buy Wheel Cleaners
    Centerbore
    This relates to the center hole in the wheel that centers the wheel on the hub of the car. Since most wheels are mass produced, they have a large center bore to accommodate several different vehicles. If this is the case, it is recommended that you use a hub ring. Hub rings are hard plastic or metal ring that fits between the wheel and the vehicle. This centers the wheel perfectly on the hub ensuring that there is no run out when the wheel is installed on to the vehicle. Without hub rings it is possible to get vibrations even if the wheel / tire assembly is perfectly balanced.
    Torque
    All alloy wheels should be installed using a torque wrench. This ensures that the wheels are not too tight or too loose. Check your vehicle's manual for correct settings. When you install wheels for the first time, you should re-torque wheels after about 100km to 150km (60 to 90 miles).
    Alloy vs. Steel
    The main differences between alloy and steel wheels lie in their durability and strength. Most high-performance wheels are made of an alloy and composed of aluminum, and other metallic substances. By using alloy wheels, you not only improve the looks of your vehicle but also the performance. The extra strength provides longevity as well as effecting tire wear in a positive manner. The weight reduction will improve steering response and handling, as well as help improve acceleration and braking.</SPAN>
    Wheel Construction
    There is a good variety of ways of constructing wheels. Most alloy wheels are made in either one, two or three piece construction types. One piece is just what it says, a wheel made in a mold as a single piece. Two piece wheels are made of two separate pieces (center and barrel) that are usually welded or bolted together. Three piece wheels are made of three separate pieces. They have a center, and inside rim half, and an outside rim half. They are bolted together using the highest quality fasteners.
    Manufacturing method is very important in the overall quality and performance of a wheel.
    Here are the most common types of manufacturing techniques employed:
    Forging
    Considered to be the best manufacturing technique, forging allows for the compression of an aluminum billet (one solid piece of aluminum) into an aluminum wheel using over 13 million pounds of pressure combined with heat. This produces a wheel that is both stronger and lighter then your standard aluminum wheel. A subset of forging is called roll forging. In this process, a metal blank is run through rollers with impressions sunk in to their surface giving the wheel its final shape. This allows the wheel to be produced with less aluminum, reducing weight but maintaining strength.
    Low Pressure Casting
    This is the most common form of rim manufacturing. Much like a casting, liquid metal is poured into a mold and allowed to harden until the finished wheel is cool enough to be taken out of the casting.
    Counter Pressure Casting
    Opposite to low pressure casting, the liquid metal is not poured, rather it is sucked into the mold using a vacuum. This reduces impurities making the wheel much stronger than a low pressure cast rim.
    Hardware
    The hardware holding your wheels to your car is an often overlooked step when installing new rims. Most aftermarket wheels require different wheel nuts / bolts than what was used on the original equipment wheels. Wheel nuts and bolts have many different seats (where the nut touches the wheel). The 3 most common are acorn seat (conical), ball seat (radius), and mag shank seat. These differences along with different lengths and diameters makes hardware very confusing. Always check with the people who supplied your wheels for the correct mounting hardware before trying to install them on your vehicle..
    ...Hope that helps!
    Sr Member majic's Avatar
    Aug 2004
    Default Re: A-Z of RIM INFORMATION
    Jun 2006
    Whoa, I missed that. Do you want to merge it Maj, or delete?
    I just wanted a hard copy on the site, not linked. Can we merge?
    Aug 2004
    i personaly like the one i linked b/c it's updated fairly reguraily and it's colour coded and all so we could take a snapshot of that but i'm not sure about copyrights.. so i just linked to it.. the guy has graphs and java applets and all in there.. up to you mang..
    Jun 2006
    Merge it under your name, the posts will end up under your links because there newer, and personally I like you links better. I just like having a hard copy on the site. Plus its not quite as long.
    Feb 2007
    How about more Mazda3 specific.
    What is the max off-sets for stock suspension on a 17" rim.
    Or an 18" rim? for no-rub fitment etc.
    I am looking at getting some rims for the car now and am not sure what off-set to get.
    They are 17" and have a 42mm off-set, I think they will fit, but will they fill the well , or look like stock?
    Anybody?
    Jun 2006
    Well here are some numbers for you:
    STOCK:
    17 x 6.5 offset 52.5mm
    FEASABLE (if lowered):
    17 x 7.5 offset 42 - 52mm
    17 x 8 offset 45 - 50mm
    18 x 7 offset 42 - 55mm
    18 x 7.5 offset 42 (some rub) - 50mm
    18 x 8 offset 48 - 50mm (very tight) look for some rub.
    19 x 7.5 45 - 50mm
    19 x 8 (probably won't fit if your lowered)
    Rims fitting depend on if your lowered and by how much. Most rims 7.5" and wider will require you to roll the fender if you're lowered.
    Its recommended not to go with a tire larger/wider than 225/40/18. The good thing is the rolling circumfrance of that size is pretty much the same as stock.
    If a rim has a lower offset its possible to use a narrower tire for slightly more clearence.
    Spring make the differance also, so be aware when you lower your car. The preferable offsets for us are between 52 and 45, with 42 possible. Be aware of the weight in your car and the roads around you in your decision.
    Hope that helps.
    Feb 2007
    So a 42mm off-set moves the rim outward more than stock?
    Jun 2006
    Yes by 10mm +/- the difference in rim width.
    Feb 2007
    Jul 2006
    "Spring make the differance also, so be aware when you lower your car. The preferable offsets for us are between 52 and 45, with 42 possible. Be aware of the weight in your car and the roads around you in your decision."
    What does the weight of the car, or the roads have to do with the offset?
    My Mods:
    Subtle but there.
    Jun 2006
    Quote Originally Posted by wingnut12 View Post
    It has nothing to do with offset. It should influence your decision. If you are not lowering your car you can possibly use a lower offset because it won't rub.
    Weight wise, if you continually transport people in your car you won't want to lower onto 225mm because it will most likely rub.
    You also won't want 30 series profile on pothole infested roads.
    The moral of the story is to consider all elements in your tire and rims buying decisions.
    Jul 2006
    That made a lot of sense to me after you explained it to me as I had never really thought it through.
    Default wheels & tires
    Looking for set of 16" rims for 2006 Mazda 3 Sport to replace original 17" set.
    Will trade or purchase. Current set of original rims & tires have 45K on them.
    Newbie E-POTS's Avatar
    Mar 2010
    Maple
    I'll just throw this in, for the 2010 Mazda
    stock rim:
    17 x 7
    thats what it said on the backside of my GT, hopefully the offset is 52.5mm as well, i'll have to recheck that
    2010 Mazda 3 Sport GT
    Sr Member rzapata's Avatar
    Jan 2011
    Downtown TO
    36 Post(s)
    Hey all,
    Just wondering if a 215 or 225 will be ok on a 17x7 wheel? My tires at the moment have 205/40/R17 profile.. I was just wondering if I can get a tire with 215/45?/R17 or 225/45?/R17.. Or it does not matter as long as the diameter is 17??
    Thanks and I appreciate all the suggestions!!
    Newbie jova87's Avatar
    Jun 2009
    2007 Mazda 3 Sedan 2.0L AT
    NEXTMOD IS MY SUPPLIER
