Shock Sensor Upgrade
You must have the factory Anti-theft system to be able to add the shock sensor (GT models only)
Approximate time required for installation:
- 45 min or less
Tools needed:
- pliers
- shock sensor install kit from Mazda (part # 0000-8F-K01A or 0000-8F-K01A-CA)
(In kit but missing from picture - 2 zip ties)
1. Remove the passenger side door sill by carefully pulling upward.
2. Remove the pushpin on the passenger side kick panel.
3. To remove the passenger side kick panel, carefully pull it towards the rear of the vehicle.
4. Remove the electrical tape on the main harness to expose the bundle of wires.
Separate the bundle of wires to access the appropriate wires for installation.
5. Locate the Black and Red wire for the diode jumper installation.
Be aware that there is also a BROWN & RED wire that looks very similar. DO NOT USE CONFUSE THE TWO.
6. Cut the Black/Red wire approximately 2 inches down from the main harness wrapping.
7. Pre-assemble the diode jumper as shown. For ease of installation make sure the Brown Diode wire
is in the pass through side of the connector, and the molded stops are used on the brown wires.
8. Install the Brown Diode wire (side w/o label) to the lower cut end of the Black/Red wire.
Next install the label end to the top side of the cut Black/Red wire.
9. Locate the following 3 wires in the OEM harness.
Red
Orange with Yellow stripe - Make sure it is a yellow stripe. In some cases the yellow has faded and almost looked white.
Black
10. Attach a red T-Tap to each as shown.
11. Attach a red T-Tap to the Black/Red wire, just above the connector from the Brown diode wire (with the label).
12. Attach the shock sensor harness to the T-Taps.
Shock Sensor Vehicle Wire
Red ............................... Red
Orange ........................... Orange/Yellow stripe
Brown ............................ Brown diode wire
Black ............................. Black
13. Use one tie wrap to secure the shock sensor to the OEM harness above the blue connector.
Note the LED should be facing the harness with the white knob facing rearward, to allow adjustment.
The unit will be upside down, but this will not effect performance.
14. Use the second tie wrap or electrical tape to neatly capture all the loose wires from the shock sensor harness and the OEM harness. Adjust the sensitivity before reassembling the kick panel. (SEE: SETTING SENSITIVITY BELOW)
15. Reinstall the kick panel and door sill.
__________________________________________________ ______________________________________
SETTING SENSITIVITY (AS PER MAZDA)
Shock sensor is factory pre-set to be at minimum sensitivity. In order for the sensor to be effective sensitivity level MUST be checked after installation. To adjust sensitivity, use the following procedure:
A. Verify that the shock sensor’s adjustment knob is turned completely to the clockwise position (Maximum sensitivity).
B. Close all doors, hood and trunk. Arm security system using the keyless entry transmitter by pressing LOCK.
NOTE: A KEY MUST NOT BE IN THE IGNITION OR THE SECURITY SYSTEM WILL NOT ARM.
C. Strike the windshield and/or side glass firmly with the palm of your hand. The horn should sound as follows:
LIGHT IMPACT........HORN SHOULD NOT SOUND (! VERY IMPORTANT !)
HEAVY IMPACT.......SECURITY SYSTEM WILL BE TRIGGERED AND HORN WILL SOUND
DISARM BY PRESSING UNLOCK ON KEYLESS ENTRY TRANSMITTER.
NOTE: IF THE SECURITY SYSTEM IS TRIGGERED BY A GENTLE STRIKE OR THE HORN DOES NOT SOUND AT ALL. PROCEED TO STEP D.
D. Adjust sensitivity by turning the small knob on the side of the shock sensor.
REPEAT STEPS B & C UNTIL DESIRED LEVEL OF SENSITIVITY IS ACHIEVED.
If the horn sounds but does not sound after 2nd or 3rd test, then the diode is backwards or the wire tap connected to the diode assembly (from the shock sensor) is on the wrong side of the diode. IF THIS OCCURS THE SHOCK SENSOR MUST BE REPLACED AFTER CORRECTING THE CONNECTION(S).
E. To avoid any false triggers, a final test of the shock sensor should be performed by the following test while the system is armed. A light impact should NOT trigger the alarm system. If this happens, a false trigger will occur in the field and the system should be re-adjusted.
*Drop a tennis ball from 1 meter above the windshield.
*If the system triggers, it must be turned down and retested.
Just a comment from me...
A tennis ball never touched my car during this whole process and I wouldn't recommend it either. The palm of your hand works just fine.
