A long time in the making. MadDad(TM) Clarity Ultra Series gauges are like nothing you've seen before. From their larger than life 66mm faces(universal 60mm mounting) with the clean OEM look Clarity gauges are famous for, to the wireless remote that replaces unsightly control boxes these gauges represent the flagship in the MadDad(TM) Clarity line. The 3 gauge bundle offers a huge discount on the individual gauge prices and includes the $40 dollar wireless remote for FREE. MadDad(TM) Clarity Ultra gauges can claim bragging rights in your car with the following features:
* 66mm gauge faces are larger than the competitions filling out a 3 gauge 60mm(they fit into a 60mm pod) pod very nicely. The large face combined with the logo free design Clarity gauges are famous for means easy at a glance reading like no others.
* Power on needle sweep very similiar to a Subaru Impreza WRX/STi with only the needle lit up on the initial single startup sweep.
* The latest generation of LED backlighting. Visibility is not washed away on sunny days unlike most "smoked" lens blackout gauges.
* Amber/Red backlight matching a Subaru Impreza WRX/STi and many other cars such as Mitsubishi EVO.
* User adjustable warning lamp. (lamp lights and needle flashes)
* Audible warning - can be turned on/off.
* External Warnign Lamp Port - each gauge will interface with large external warning lamp(shift light type) available separately
* External Device Control Port - allows adding functions to the gauge, using the gauge face as a device control panel:
* Turbo Timer - intefaces with Boost gauge Control Port. Adds turbo timer function. Set run time using gauge face/needle. Require use of wireless remote(including in all 3 gauge bundles).
* Aux. Radiator Fan Contorl - interfaces with water temp gauge and activates on water temp warning setting.
* Intercooler Water Spray Control - TBA
* 50 second datalog record/playback(playback on gauge face)
* Pressure gauges include calibration set function to "0" the psi level for given elevations ensuring the best accuracy.
* Peak value record and recall
* Aluminum housing to dissipate heat.
* The higheset quality sending unit available. All sending units accurate to within 1% max
* Best off all - NO CONTROL BOXES to clutter your dash and NO BUTTONS on the gauge face cluttering the clean look. All functions are controlled by a multi-function wireless remote included in all 3 gauge bundles.
