Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Rear pads & rotors
    Apr 2007
    Default Rear pads & rotors
    I went to Avante to get my 05 mazda3 hatch serviced and they told me that my rear pads and rotors have less than 5% left on them (and have a lot of rust) and that my fronts are still okay. Is it normal for the rears to wear faster than the fronts?? I have 48,500 km on my car. They quoted me $460 for pads and rotors (rear only)...is that reasonable??
    Also, is there a particular brand/type of pads & rotors I should be looking at. I've been looking at the stickies but I'd still like some opinions. Thx!
    Default Re: Rear pads & rotors
    Quote Originally Posted by steph View Post
    It seems to be a normal occurance on the 3's for the rear pads to wear sooner then the fronts ...But what you should be questioning is why they (the rear pads) are worn down to less than 5% at such low a mileage! You must have a problem there somewhere; either with the caliper(s) or possibly parking brake assembly....which are both still covered under warranty, (if you are under 3 years that is.)...You should discuss this 'problem' with the service advisor because less then 5% at 48k~is not normal wear.
    If the dealer does not agree to replace the components under a warranty issue then I would suggest going with Magnum rotors and Hawk pads, they are cheaper then oem and IMO, better quality.
    Apr 2007
    I questioned the dealer the brakes have worn down so low already and why the rear wears quicker than the front and they said that it was normal. I think I'm going to talk to them again.
    Would having subs in the trunk increase the rate of brake wear??
    Also, what is the average normal mileage that the brakes should be changed at?
    I have my Sub and amps in the back and I replaced my pads at around 72k and there was still life left in them, so I don't think the subs would affect it much, if at all.
    I can't say whether 'my' brake life span is "average/normal", but I feel safe in saying your 48k is definitely too early....but the rear pads will (and this is from myself and other members) wear faster then the fronts~that is normal.
    Did they show you the pads last time? Was there uneven wear in the pads ie; inside to outside pads or from left (driver side) to right (Passenger side)?...that would be a tale-tell sign that something was askew. I'd have them check your calipers and parking brake for any problems, because there is definitely something wrong...If they still give you the BS, take it somewhere else.
    Sr Member Wild Weasel's Avatar
    Nov 2006
    If it were front brakes, then I'd say 50k is a reasonable amount of mileage to have to change them. I share your confusion about the rear brakes though. There's no reason for the rear brakes to wear faster than the front, but it seems to be a regular occurrance with the 3. I suspect it may have a little more brake bias toward the rear than one would expect, and the size difference means they wear out quicker.
    Most of the braking power comes from the front, so logic dictates that those should wear out first, but there's also more meat up there to last longer.
    Jr Member 06Touring3's Avatar
    Jun 2006
    I just changed all 4 pads (and front rotors) at 74k and my rear pads had probably 80% left still while my fronts had around 5%...so i don't encounter the same problem that is apparently "normal".....
    My rear pads are still wearing off the break-in coating that EBC pads have while my fronts have been fine for weeks now...so it seems i have the exact opposite scenario as other people
    '06-3iTE-5Spd
    TWM|EBC|Prolumen|Simota|Progress|Fast
    20%-Tint|Broken-Fogs|Indy-Fogs|Moldingless|Stubby
    Apr 2007
    They didn't show me anything, but it was written on my inspection sheet that I have .2 mm left on one side and .3 mm left in the other in the rear. I think I have 3 mm left on both sides in the front (I'm at work & don't have the sheet with me). So, I guess that means that there is uneven wear in the back but they didn't say anything to me.
    I've been looking at Wagner ultra quiet pads... are they any good??
    Apr 2007
    Quote Originally Posted by 06Touring3 View Post
    Wow, that's weird that its totally opposite for our cars.
    Where did you get your brakes done and what kind did you get? If you don't mind me asking....
    Jun 2006
    My friend did my brakes he's a mechanic....and I have EBC front rotors and EBC greenstuff pads all around
    Jun 2008
    I just purchased Magnum X-Drilled Rotors mainly because they were one of the cheapest I could find. Cheaper than dealer or OEM's at other stores.
    It cost me $130 for all four.
    My Hawk HPS pads just came in the other day so just a few more days til rotors arrive.
    Sr Member Noisy Crow's Avatar
    Make sure your parking brake is releasing properly.
    Apr 2007
    I told my dad's mechanic about it and he's going to take a look at the parking break for me.
    Is anybody using Raybestos brake pads and/or rotors??
    That's what I'm probably going to end up getting seeing how that's what my dad's mechanic uses and he's going to be working on my car.
    Get a price on them first and then compare with what you can get thru here; for instance you can get Hawk HPS all around for about $180 taxs in....and Raybestos do not compare in quality....IMO.
    Apr 2007
    He quoted me $386 for parts and labour ($150 for labour). I think the pads are around $76 for the pair and $115 for the rotors. Who would I get the Hawk pads from through here??
    Member WeatherB's Avatar
    Apr 2007
    $150 is too much for labour. Changing the pads takes less than 1/2 hour.
    Jun 2008
    I ended up buying Hawk HPS front and rear pads from Gary @ bigbrakparts.net. It cost me $177 (including $30 shipping).
    Jun 2008
    Quote Originally Posted by WeatherB View Post
    I talked to Jimmy @ StreetPerformance recently. He claims he can do for 1/3 of that price.
    Dec 2005
    There is a difference between just changing pads/ rotors with changing pads/rotors PLUS servicing the brakes. The ongoing rate for changing 4rotors/4pads with servicing the calipers should go for about $130-$140 while some mechanics are willing to change just front and rear pads for $50.
    Dec 2005
    Well... just to be fair, some garages have more overheads than others, and so they have to charge more.
    Jr Member nicker's Avatar
    Jun 2007
    that is totally odd that the rears went faster then the fronts, I personally have never heard or seen that before. Either way for that price Id get complete set of slotted/drilled roters and pads and do the install your self.
    07 Mazda 3 GT Sport 5spd , Carbon Grey Mica, 35% tint, stubby, black Calipers, Tinted side indicators, Tinted Rear Reflectors.
    Newbie Cozwell's Avatar
    Nov 2005
    I had the same with my rears @ 92k i just replaced all 4 pads and rotors...
    Kristian aka Cozwell
    Twitter: www.twitter.com/kristianward
    Blog: www.kristianward.com (Now Live)
    My Company: www.wardnco.com - Small Business Marketing Agency
    Linkedin: http://ca.linkedin.com/in/kristianward
    My Radio Station: Jbradio.fm
    Nov 2006
    Quote Originally Posted by karsia323 View Post
    Correct me if I'm wrong, but "servicing" the brakes doesn't generally include bleeding them, right?
    If that's the case... then what do you think they're doing other than blowing off dust and putting some lube on the sliders?
    Jun 2008
    Quote Originally Posted by Wild Weasel View Post
    Dismantaling the sliders, cleaning off rust, filing down any uneaven wear that may hang up the pads and cause them to jam, lubricating everything... He is right, there is a BIG difference in a $50 job and a $150 job.
    - Geoff -
    2008.5 Metro Grey GT 5 spd w/LP
    ^ Your right, for $150 you think they do the job properly but just switch the pads and bleed them and then give you your car back. They are there to make money, thats it!
    Jun 2008
    That's why you go to a trusted mechanic. I go to the shop I used to work at because I know the owner well and trust his workmanship. With my old car, I had to get my rear brakes serviced at least once a year or they would seize and it would be about $120 for them.
    Oh, and Wild Weasel, I forgot to specify... No, a brake service does not include bleeding of the lines. It is just a servicing of the hardware (calipers, bracets, sliders, auto adjusters). They only bleed the lines if they open the lines somewhere, exposing the system to air. That or they do a brake fluid change, which is a seperate service.
  1. Hawk HPS rear pads don't fit
    By sic_mic in forum Suspension & Brakes
    Last Post: 06-07-2008, 08:04 AM
  2. changing rear brakes +/- rotors...advice needed.
    By resin_dr. in forum Suspension & Brakes
    Last Post: 03-27-2007, 09:57 PM
