Tokyo Drift
I just did angel eyes and independent fog light mod yesterday and
here's what I did.
1. I did indpendent fog first,
2. then disabled DRL with just pluuging out the DRL fuse
3. wired angel eyes to power source as DRL
p.s.
- you should wire the angel eyes to an empty fuse slot, NOT DRL fuse slot. If you do,
then you won't be able to turn angel eyes off even if engine's off. Since you wire them
to the empty slot, angel eyes turns on whenever engine's on)
- wire fog lights to DRL slot, then you will be able to turn it off with switch. if you keep
the switch's on, fog's on even if engine's off
