Results 1 to 25 of 29
Thread: How To: 6x8 to 6.5 speaker adapter template
    71 Post(s)
    Exclamation How To: 6x8 to 6.5 speaker adapter template
    I've created a template for anyone who wants to use it. It will allow you to use either 6.5" or 5.25" speakers in the factory locations. All you have to do is print out the template at 100% and use it to trace onto your material (MDF, plywood, plexiglass, etc).
    The template hole was made to fit a 6.5 that had a large basket. If you are using 5.25" just cut the hole smaller to accommodate the smaller speaker.
    The larger holes are for the factory mounting points/screws. The smaller holes are for the speaker mounting points. The speaker mounting points are just approximate as they worked for me, but you can pretty much put them wherever as long as they do not interfere with anything.
    For mounting the speakers - If you use screws that are longer than the thickness of the adapter, they may run into the plastic behind the adapter. So try using smaller screws.
    Download template PDF here
    96 Post(s)
    Default Re: How To - 6x8 to 6.5 speaker adapter template
    Mods, Give this man a STICKY
    Mar 2008
    79 Post(s)
    dope.
    Jun 2008
    good to know if i ever (and i mean, ever) get around to starting on the audio in my 3...
    now where was that link for the adapter that allows you to use the steering wheel controls with an aftermarket deck......
    Nov 2008
    very sweet
    Sr Member 07carbon3's Avatar
    Aug 2011
    Toronto,Beaches
    2007 Mazda 3
    97 Post(s)
    Default Re: How To: 6x8 to 6.5 speaker adapter template
    do you have a template for putting in a 6.5speaker into a 5x7 speaker?
    24 Post(s)
    Quote Originally Posted by 07carbon3 View Post
    First post cwp has a downloadable template.
    Just down load it then print it
    Aug 2011
    Toronto,Beaches
    2007 Mazda 3
    97 Post(s)
    Default
    Is there any where in the east Toronto area where I could buy adapter Like what cwp made,
    I would make but im lacking in the tools to do it nicely
    Or is there anyone who could make them for me I'd be willing to buy from a member here
    #FREESHINGLEZ
    24 Post(s)
    Crutchfeild makes them... Give them a call or check them online
    Aug 2011
    Toronto,Beaches
    2007 Mazda 3
    97 Post(s)
    Default
    Quote Originally Posted by aris View Post
    Do they have a toronto store or just a Canadian online shop?
    I was looking for a brick and mortar shop to get it immediately and not pay shipping but I'll still check them out
    71 Post(s)
    If you can't wait, call one of the audio sponsors or FS/BB. If you can wait either go through Crutchfield Canada or these guys on Ebay. They are legit and this is where I made my template from.
    Sep 2011
    for reference I just got out of a chat with crutchfield.
    According to them, 2010+ mazdas have the following restrictions for when you size a speaker:
    Magnet diameter: 2.7" for the front and 2.9" for the rear.
    Depth: 1.9" in the front and 3.3" in the rear.
    Jan 2012
    Depending on the speaker you plan on putting in to your factory speaker cavity. using pre-made speaker plates may cause the new speaker magnet to interfere with the power window mechanism, also some aftermarket speakers have different size and shape speaker baskets which may not sit properly into pre-made plates. also pre-made plates made of plastic or PVC can vibrate and leak causing sound distortion. the best option is using 1/2 inch MDF and cutting your own spacer plates with a jig saw, this method lets you make a custom mount for not only you vehicle, but also for your new speaker. the MDF has enough flexibility to mount securely to the door panel with out vibrating or leaking.
    Sr Member stevenma188's Avatar
    Aug 2009
    Edmonton
    Thanks for the template man. For the issue of running longer screws, I just rotated where the speaker sat on the adapter and it will fit inside of the stock opening.
    CURRENT: 2008 Subaru Impreza STI | 1986 BMW 325 5.0L V8 Swap | 2006 Dodge Ram 1500 | 2004 Ford F-350 | 1993 Toyota 4Runner | 2003 BMW 325i | 1991 BMW 325i
    GONE: 2005 Mazda 3 Sport GS | 1998 BMW 328i | 1992 Mazda Miata | 1986 BMW 325e | 2000 BMW 323ci | 2003 Dodge Ram 1500 | 1999 Volvo S70 AWD | 1986 BMW 325es | 2002 BMW X5 4.4i | 1998 Mitsubishi Evo V
    Jan 2013
    mississauga
    I have a 04 GT, will this template work for me
    389 Post(s)
    Quote Originally Posted by crank View Post
    yes
    Jan 2013
    mississauga
    Thnxs
    Jr Member oxide's Avatar
    Jan 2011
    Winnipeg MB Canada
    oops
    Jackhouse - yer online guide to all things House news/interviews/reviews
    https://twitter.com/JACKH0USE
    Fridays
    sHIFT Radio 101.5 9-11pm http://www.umfm.com
    http://soundcloud.com/oxide
    http://oxide.bandcamp.com/
    07 Yaris HB
    05 Yamaha Vino 70CC Heavily Modded
    Jan 2011
    Winnipeg MB Canada
    i have an 07, do i need this template or does a 6X8 fit into the stock 5X7 speaker hole already, trying to find some details on here but not getting accurate ones, any help? crutchfield even says 6X8 fits...
    thanks
    71 Post(s)
    6x8 should fit without any additional template.
    Jan 2011
    Winnipeg MB Canada
    thank you for your help
    Noob Everlaid's Avatar
    Sep 2013
    Etobikoke
    Great i will try it. The bose really sucks
    Member staax's Avatar
    Apr 2014
    Ottawa, ON
    2002 Dodge Dakota
    36 Post(s)
    Not trying to revive this thread, but its better than creating a new one.
    Does anyone have a copy of the PDF template I see that's listed above? The link no longer works (atleast for me).
    I plan on running Kicker KS60's in all 4 doors and just making my own mounts out of MDF.
    389 Post(s)
    Quote Originally Posted by staax View Post
    @staax link works fine for me..
    Sep 2014
    Anyone know if 6x9 speakers will fit in an 05 mazda3 sedan? been looking online but no luck
  1. Speaker wire
    By VetalM3 in forum I.C.E (In-Car Entertainment)
    Last Post: 08-31-2008, 08:18 PM
  2. Distorted Speaker, perhaps?
    By Lars in forum Problems with the Mazda3
    Last Post: 11-12-2007, 03:01 AM
  3. Factory Speaker Q?
    By mogul_pro in forum I.C.E (In-Car Entertainment)
    Last Post: 11-02-2007, 10:48 PM
