x_o_k_x
50% of people on prokits dont have cambers, becasue its only mild drop and tire wear in minimal. So instead of 3 years on 1 set of tires, it will last you for 2 years. With sportlines, the drop is almost 2 inches, the stock camber will not fix alignment, so your tire wear will be noticeable after few weeks maybe.
If you want to save tires and reduce headaches, just get cambers.
Some people also say that on prokits, you might not even need adjustable cambers. So you can try getting alignment fixed and see if that helps if not, then you will need 2nd allignment after cambers installed.
