Results 1 to 10 of 10
Thread: Weird Feeling In Clutch
    Newbie hood's Avatar
    Jul 2007
    Default Weird Feeling In Clutch
    Hey guys,
    When my clutch is fully depressed and i turn my wheel without moving i can feel a very noticable taping feeling on my clutch. Anyone know what this could be? My car drives perfectly fine and theres no weird noises come from anything.
    Velocity Red Mica 2005 Mazda 3 GT:
    - Fujita 5 CAI - AEM Dry Flow Fliter - RX-8 Rims (Black)- Eibach prokits - Vibrant Strut Bar - Apexcone 6000k - Tints 35% front, 20% rear - Exedy Flywheel - Exedy Stage 1 Clutch - Hotchkis Front and Rear Sways - SPC Rear Camber arms - 3000K Fogs - SU Side Mounts - CPE Rear Mount
    Oct 2008
    Default Re: Weird Feeling In Clutch
    hmmm, let me check some more M3s so I can tell if this is normal.
    Newbie Ziploc's Avatar
    Nov 2008
    If you keep the engine at a higher RPM, say 1,500RPM, does the tapping still happen?
    Member sudz's Avatar
    7 Post(s)
    Check the revs if they drop significantly when you turn the wheel. When you're not moving, it takes a lot more umph for the power steering to turn your tires. My brothers old pickup didn't have power steering... you'd start sweating buckets trying to navigate a parking lot!
    Sr Member Donutz's Avatar
    Dec 2005
    Quote Originally Posted by hood View Post
    When my clutch is fully depressed...
    I don't think it has to do with his revs peeps; read the OP. I get the feeling the clutch is pushed to the floor.
    Is not here
    Jul 2007
    yes the clutch is pressed to the floor and i still feel a tapping feeling like sunthing is hitting it
    Jul 2007
    i also feel it when the car is rolling slowly
    Jul 2007
    I get the feeling when im driving at normal speeds around corners
    Oct 2008
    clutch hydraulics maybe going? or air pockets in the lines?
    Oct 2008
    I do feel tapping on the clutch pedal from some Mazda 3 and Mazda 6. It's more noticeable when RPM changes. My feeling is the clutch finger springs may deformed by heat, or the pilot bearing/release bearing is going south. Some release bearings from other make/models have dampening spring washer install to lessen the tapping, but on Mazda, they don't have it.
  1. 06 MS6 Clutch Engagement point varies
    By PlatMS6 in forum MazdaSpeed3 Stock Issues
    Last Post: 10-15-2008, 02:38 PM
  2. Clutch Issue
    By carTun3 in forum Engine & Drivetrain
    Last Post: 11-01-2007, 09:17 AM
  3. Clutch Problems Since 5k!!
    By Axela3z in forum Engine & Drivetrain
    Last Post: 07-24-2007, 01:08 AM
  4. clutch problems
    By ///M in forum Problems with the Mazda3
    Last Post: 12-10-2005, 01:41 AM
