Results 1 to 2 of 2
Thread: Checking the oil filter casing?
    Sep 2007
    Default Checking the oil filter casing?
    Ok, this forum has made me paranoid about the plastic casing on my oil filter (2.3L 2006 3).
    Is there any way to reliably inspect it yourself after an oil change? I don't have jackets (other than the spare).
    Any tips, advice?
    Member mazda lover's Avatar
    Aug 2005
    Default Re: Checking the oil filter casing?
    Quote Originally Posted by maoro View Post
    Any tips, advice?
    Only way I know is to crawl under the car and with a light visually inspect it through the splash guard hole...thats what they do at the factory! so they say...also check if you get any oil drops on the ground after an oil change, check your oil level everyday for a few weeks, if level and no oil drips on the ground you should be good to go...just my opinion...
  1. Oil Information Thread
    By Mazda3X2 in forum Engine & Drivetrain
    Last Post: 09-01-2014, 01:18 PM
  2. Almost Dead Engine From Cracked 2.3L Oil Filter Housing
    By RedRaptor in forum Problems with the Mazda3
    Last Post: 03-23-2009, 12:09 PM
  3. Maintenance at the dealer
    By monstar in forum Mazda3 General Discussion
    Last Post: 06-18-2008, 07:40 PM
  4. How To: Oil and Filter Change
    By MajesticBlueNTO in forum How-To Guides & Reference
    Last Post: 08-16-2006, 09:07 PM
