When shifting hard into second gear in slippery conditions (IE: traction light blinking throughout first), will the stability control hit your brakes hard to the point where you notice it and it bogs down? Either that or I really had a bad shift... I've never bogged down the engine throwing it into 2nd gear... Mind you, I did release the clutch aggressively/very quickly, but I was near redline, there's no way the engine should bog down in that case... Was it a horrible shift or traction control?
