Ok, I did a search and I am not sure if the sqeeling problem other people have mentioned is the same as mine. The brakes work fine in terms of performance but when I am at a full stop and very slowly release the brakes, it squeels pretty bad. It sounds and feels like the pad and rotor are rubbing against each other and not moving against each other smoothly. I have just installed ceramic pads but still have the OEM rotor in front. This only happens as I am almost at a complete stop and when starting to move or creep forward. This happens even when the brakes are all heated up after driving for a while. Any idea what it might be or how to fix it?
