So I have a hard time getting smooth shifts between gears 1-2 and 2-3. From everything I read its the rear engine mount and the shifter bushings that are the culpurits of this.
The shifter bushings are a definate change, they are cheap and no brainers.
But the rear mount is where I have questions, what are you guys running? and what do you recommend? Right now the 2 that I see are the SU Rear Engine mount and the CPe Rear Mount. I saw a thread (I think from Fobio, correct me if I am wrong) where his mount failed (it was a SU mount). I personally dont want to buy a part where I am going to have a worry that it may fail (not saying that it is, but you get what i mean). The CPe mount is a tad bit more, but apparently its a very good mount with minimal vibrations.
I have heard of the TRZ dogbone, but that has CRAZY vibrations and I definatly dont want crazy vibrations.
Anyone have any recommendations? or what they use? any word on the failrate of the SU mounts (I also remember reading it could have been a bad batch)?
