Hi Guys ,
I have a noticeable Transmission Jerking from 2nd to 1st (yes 2nd to 1st) when I stop the car , I have a 2008.5 mazda3 hatch AUTO.
does anyone have this issue? or just me ?
thx
Hi Guys ,
thx
I think a couple of people have had similar issues... mine has always jerked from 1st-2nd, and more recently a slight jerk in 2nd-3rd. I got used to it tho... I find if i step on the gas a little it's less noticeable...
maybe someone else can chime in as to whether it's something that sound be fixed under the drivetrain warranty?... you definitely aren't alone on that one tho.
I had the issue in the past. I had the dealer flash the PCM, and it was updated and went back to learning mode. All was well. Not sure about the warranty piece though..
if he has an 08.5 would that not fall under the 3yr 80k warranty....or would they put this under their 1 yr 20k warranty for adjustments and such like that? I know I had the problem of the shift shock and got MOT to do the flash update....but I was within my first yr and under 20k...
I think that's what I had done.... it was fine for a bit but it's back again. Try it anyway tho.... and you don't have to be under the 1yr 20k (or 3yr) either.
I have an 05 auto and when I go from 4th to 3rd (sport mode) I get a bit of a vibration. Dealer said all was normal as all they did was check the fluid level and its colour. Had the PMC reflashed was OK for a while but returned, also the morning shift shock was eliminated but returned. Dealer will tell you its normal unless the vibration-jerking is very bad.
just make sure the computer programming all gets updated to the latest... and if its still happening, try to change the fluid out first then go from there
if the pcm update doesn't solve the problem I've had luck with clearing the KAM (keep alive memory). negative battery terminal disconnect for a few minutes and reconnect. usually I do this when the rpm fluctuates on deceleration. feels like transmission but it's not. happens at the same rpm every time.
PCM has been updated but I still have the harsh shifting
Ahhh, all this computer crap lol. I had the same problem, then it went away after I went for a service at the dealer. I guess they upgraded mines as well.
Too Many Mods To ListPicture Gallery: http://www.torontomazda3.ca/forum/sh...ad.php?t=37634
try adding a bottle of lubegard.... maybe it'll help!
uhh... if you're using manual mode, it's going to jerk on downshift no matter what! it's called lack of rev matching!
i get the jerking from 3rd to 4th. i don't feel it if I ease off on the gas before it shifts. wondering of disconnecting the batt for a few minutes will help
