Results 1 to 17 of 17
Thread: oil pressure gauge?
    Official TM3 food tester froggy's Avatar
    Jan 2009
    Default oil pressure gauge?
    just wondering I'm sure the computer automatically checks the oil pressure but on my gx is there an easy way to get it displayed on a gauge? and if not does the 2.0 L block have an access plug screw to install one in?
    there's no such thing as too much zoom zoom
    Thanks to MazdaBetty for the avatar
    Quote Originally Posted by mazdabetty View Post
    OHHHHH I HATED IT when people used to steal my pole
    Sr Member Zoom Zoom Boy's Avatar
    Aug 2008
    Default Re: oil pressure gauge?
    Don't know Froggy. I do know that the MS3 has an access plug screw and setting up a gauge is still a pain in the ass if you want a proper and clean install. Your best bet would be to call Jimmy or maybe 'The Man' or 'Aaron the Prima Tech' will see this and post up.
    Good luck in any case.
    - Courtesy of Unoriginalusername
    "Friends don't let friends, apex early."- unknown
    2008.5 Black Mica Mazdaspeed3
    2005 Titanium Grey, 5spd, GT Sport Hatch
    Jan 2009
    yeah i was just wondering, since when i was changing my oil i see a lot of plugged holes in the bottom of the block and i was figuring that's probably what it's for. do the ms3's share the same block and are just over bored/stroked to get the extra displacement?
    Noob jurgenk's Avatar
    Oct 2008
    I have a 2.0L GX hatch and installed an electrical oil pressure gauge in a vent pod using a sandwich adaptor on the oil filter (gives you 4 ports for senders or you can simply plug the ones you do not use). The installation requires running a wire through the firewall from the sender and then tapping into two power wires and one ground.
    Brad
    Jr Member Mty Mous's Avatar
    Feb 2009
    '93 RX7 R1
    I bought the spin-on filter attachment and the port for the stock oil pressure sensor is 1\4" ... picked up a brass 1\4" T-Connector (1 Male, 2 Female) for $5.
    Now I just gotta find an aftermarket oil pressure gauge that uses a 1\4" sensor and I'll be set!
    Anyways, thought you might wanna know of that option.
    Jan 2009
    Quote Originally Posted by jurgenk View Post
    Brad
    wow that doesn't actually sound that difficult at all where did you pick it up? Do any of our sponsors have those parts for sale? That sounds much easier than setting up or unplugging a plug to run a probe. I was actually thinking of using a ventpod I was just wondering if anyone made a multifunction one? something that I could switch to different inputs, ie have it be able to display more than 1 thing (obviously not at the same time)
    I'd like to be able to monitor oil pressure/temp, and coolant temp, not just a scale without numbers.
    Jan 2009
    Quote Originally Posted by Mty Mous View Post
    thanks for that but my gx is already equipped with a spin on filter so i wouldn't need to go through all extra work. Thanks for the input though
    Oct 2008
    Quote Originally Posted by froggy View Post
    froggy, here is a thread from m3f on mounting a Aeroforce Scan Gauge in a vent gauge pod. He is using a different type of vent gauge pod so ignore the installation of the pod as it is simpler than that thread makes it appear. I do not have any experience with the multifunction gauges of this type so I cannot help you there but I will post back with links to the vent gauge pod and the sandwich adaptor I used later.
    Brad
    Jan 2009
    thanks dude that'll help a lot. I'll also have to look at the oil cooler mod, and probably do them both at the same time
    Oct 2008
    Adaptor plate from glowshift:
    http://www.glowshiftdirect.com/oilfi...5thread-1.aspx
    Vent Gauge Pod from therpmstore:
    http://www.therpmstore.com/product_i...roducts_id=846
    Brad
    Member JohnyGT's Avatar
    Oct 2008
    Ive recently purchased glowshift gauges & sandwich adapter,
    make sure you get 3/4 UNF16 one for the adapter.
    And unfortunately, they dont have one for 2.3L motors, so guess ill convert
    my oil filter to 2.0 from 2.3
    Froggy,
    I'll check if my Scanguage II has oil pressure. It definitely adds coolant temp, which the 2010 Mazda3 lacks.
    2010 Mazda3 Graphite Mica GS Auto with Comfort Package
    Jan 2009
    Quote Originally Posted by Chester_Lampwick View Post
    Froggy,
    that would be cool if you could is that a gauge size that would fit into a ventpod setup?
    No, it wouldn't fit into a round pod. It's rectangular, maybe 5" wide by 2" high.
    For some reason I thought you had a 2010. I could recommend a spot for it on a 2010.
    Jan 2009
    that's to bad it would be great to have some thing like that in a vent pod size. I wonder where else on an 08 3 that would blend in? 5 x 2" eh??
    Oct 2008
    froggy, Aeroforce makes the Interceptor which is a multi-function 52mm gauge that would fit in a vent pod. Expensive at $250 USD on the website but I imagine any multi-function gauge is not going to be cheap.
    Brad
    Jan 2009
    well for something you buy only once i'm not worried about spending the money, I was just hoping the sponsors might have something I'd rather deal locally if possible.
  1. Oil Information Thread
    By Mazda3X2 in forum Engine & Drivetrain
    Last Post: 09-01-2014, 01:18 PM
  2. Oil Pressure Gauge - Where to mount?
    By RNUOVR in forum Interior Styling & Appearance
    Last Post: 03-01-2009, 08:07 PM
  3. Check Engine Light + Low Oil Pressure Light
    By lukel90 in forum Problems with the Mazda3
    Last Post: 08-24-2006, 05:39 PM
  4. How To: Oil and Filter Change
    By MajesticBlueNTO in forum How-To Guides & Reference
    Last Post: 08-16-2006, 09:07 PM
