Results 1 to 11 of 11
Thread: Small oil spot in driveway
    Noob matt2112's Avatar
    Oct 2008
    Default Small oil spot in driveway
    Well I did the unthinkable and had my oil changed at Mr. Lube yesterday as opposed to the dealership. I still feel guilty for doing so, but I was in a pinch and they were the closest option. (Will not be doing this again.)
    Anyway, things seem to be running fine, however I noticed a small 'donut-sized' spot of oil in my driveway this morning.
    Is this sort of thing normal or should I be concerned?
    Member Ogata's Avatar
    Default Re: Small oil spot in driveway
    Quote Originally Posted by matt2112 View Post
    I would get it checked for one of our reputable shops. Have you tried Jimmy at Street Performance?
    2008.5 Metropolitan Grey Mica Mazda 3 GT Hatch with Luxury Package DONE: OEM LED Side Mirror Turn Signals | TM3 Decals / Plates | Axela Badge | 3M Scotchguard Film on Front Hood / Fenders | Solarguard Quantum Tints 37% Front 28% Back | Flipkey | JDM Rainguards | MS3 Rear Valence | Super White LED Interior / Trunk / License Plate Lights | Smoked LED Sidermarkers | Powdercoated Blue 18" OZ Ultraleggera Rims | Michelin Pilot Sport AS3 | Blue Calipers with Gunmetal Axela Decals | HID 6000K/3000K with Yellow Film Fogs | Hella Tones | Rally Armor Mudflaps | Powdercoated Gunmetal Xenon Expert Aluminum Pedals | Clear Reflectors | Carbon Fibre Rear Emblem Insert | Redline Elite Hood Lifts | CP-E Tow Plate | Her: 2012 Sky Blue Mica Mazda 3 GS
    Sr Member Soyabean's Avatar
    Oct 2007
    9 Post(s)
    the doughnuts i eat are fairly huge lol. But joking aside, get it checked. Might be the fact that they did not tighten the filter properly. That happened to my old car one time when i did it. I dunno how it works with the mazdas 3s and their plastic filter things
    Member mazda lover's Avatar
    Aug 2005
    if you have the 2.3 they might have not tightin it properly or they over torched and cracked the plastic housing that holds the filter. Oil droppings is not normal like bird droppings...
    Dec 2007
    could be just the old oil dripping off but i would just keep an eye on the oil levels and do a quick look underneath if you can see any oil drips/leaks.
    Don't be an idiot, it's not an M3.
    Sr Member Gizzmo_jr's Avatar
    You've only seen one spot? If you see more I'm calling it the machanic over torqued the plastic housing (easily done, it's like 15ft/lbs by spec if I recall). Not only that but crush/pinch style oil filter wrenches would crack the cap.
    There's not alot plastic to grip and not only that Mazda used an odd flute count.
    Diesel tractor...
    Oct 2008
    Yeah there seems to be just one centralized location for the oil drip. I took it out for a drive today, parked it and about 10 minutes later I saw a new spot starting to form.
    What do you suggest I do? Does the whole job need to be redone if it is a cracked plastic housing?
    Matt
    Well obviously you haven't blown the motor but I'd be double checking the fluid level almost daily. If it's the cap, it's a quick fix from a new part from Mazda. But this should be outta pocket from them. Go back and tell the
    your car has a slow leak since they changed it.
    The whole housing won't need replacing (unless you can't buy the cap seperate). The rest is aluminum
    Oct 2008
    Thanks, appreciate the help!
    Aug 2005
    do the conversion to a spin on filter, search here for more info
    Sr Member Zoom Zoom Boy's Avatar
    Aug 2008
    Quote Originally Posted by mazda lover View Post
    That, or find someone who knows what the hell they are doing to work on your car from here on in. Consider it a "lessons learned".
    - Courtesy of Unoriginalusername
    "Friends don't let friends, apex early."- unknown
    2008.5 Black Mica Mazdaspeed3
    2005 Titanium Grey, 5spd, GT Sport Hatch
  1. Oil Information Thread
    By Mazda3X2 in forum Engine & Drivetrain
    Last Post: 09-01-2014, 01:18 PM
  2. confusion about the unused oil from a 5 ltr can.
    By yanky.ng in forum Engine & Drivetrain
    Last Post: 10-26-2009, 06:15 AM
  3. Maintenance at the dealer
    By monstar in forum Mazda3 General Discussion
    Last Post: 06-18-2008, 07:40 PM
  4. How To: Oil and Filter Change
    By MajesticBlueNTO in forum How-To Guides & Reference
    Last Post: 08-16-2006, 09:07 PM
