Results 1 to 25 of 36
Thread: Alarm going off for no reason?
    Newbie thesober's Avatar
    Jul 2004
    Default Alarm going off for no reason?
    Anyone have issues with the alarm going off for no reason? My car's alarm has gone off 2 times last night, so i thought someone wanted to get in. Nope, this morning, it went off again for no reason. It can't be the wind causing this. I tried rocking the car to set it off, nothing happened. My car is completely stock, no aftermarket electrical of any kind.
    Any ideas?
    05 MZ3 GT GFX
    Mar 2008
    79 Post(s)
    Default Re: Alarm going off for no reason?
    Is it going of normal or one consistent tone?
    Sr Member Fuman's Avatar
    Feb 2005
    sub.
    it happens to me too. I've no idea why either
    Sr Member JonsMazda's Avatar
    May 2007
    Your car is trying to communicate with you lol. But yea, this happened to me also when I was down in Montreal, I just reset the ecu. Never alarmed by itself anymore, not sure if it fixes the issue but it did for me.
    71 Post(s)
    Do you have a mazda remote start? Did you have a shock sensor installed with mazda at any time?
    Jul 2004
    Only thing I had done was the Door recall that strengthened the door. Was a shock sensor part of that too, because if it was, I was never able to trip it by rocking the car.
    Strange, I think i'll just unplug the battery and have it reset to see if it fixes the issue.
    71 Post(s)
    Quote Originally Posted by thesober View Post
    There were times when they did install them for some people when that recall was done. If it hasn't done this before I wouldn't assume it's the shock sensor if you "do" have one.
    Sr Member Donutz's Avatar
    Dec 2005
    It's the factory alarm correct? I have the compustar, last year my hood pin corroded causing my alarm to go off.
    Is not here
    Jul 2004
    Yup, factory alarm. I disconnected the battery and reset the ECU. Hopefully it won't go off tonight.
    Can a weak battery cause these types of oddities? (not sure if mine is weak or not) I'm still running on the original one and its my next thing to do with the car.
    19 Post(s)
    disconnecting/reconnecting the battery wouldn't cause the stock alarm to go off if that's what you're asking
    however, if the shock sensor (part of recall) or the remote start's (mazda one) shock sensor is flaking out, then it could be doing this
    Jul 2004
    Welp, resetting the ECU didnt work, car went off 4 times yesterday, no shock sensor either.(i checked my invoice with the door recall) Does anyone know how to disable the alarm? I checked the fuses thinking i can just pull the alarm fuse, but that slot was empty to begin with. Ah well, I think i'll have to bring it in.
    Can anyone recommend a place that can diagnose this? Or does anyone know how to disable it? I just need to be able to lock the doors and not worry about it going off in the middle of the night.
    Im not worried about it getting broken into, the thing probably wouldnt even go off anyways!
    Mar 2008
    79 Post(s)
    Quote Originally Posted by Dave_The_BMXER View Post
    You never answered this...
    Jul 2004
    oh sorry, it's the same sound and actions as if you pressed the panic button.
    May 2007
    Hmm, maybe something wrong with ur panick button function, try taking the battery out and not putting it back for awhile
    Mar 2008
    79 Post(s)
    Ok then your problem is not the same as mine... be thankful!
    Jr Member MRT_MS3's Avatar
    Sep 2008
    My bet is a corroded/bad door pin.
    2008.5 CWP MS3
    Feb 2010
    So, was the problem ever solved. My son left his 2005 Mazda3 with me when he went away and the alarm is going off 2 to 3 times a day.
    71 Post(s)
    Quote Originally Posted by aharonpow View Post
    Does your sons car have the stock alarm or an aftermarket alarm?
    Feb 2010
    He has the stock alarm.
    Sep 2004
    Exclamation Re: Alarm going off for no reason?
    Help!
    Anyone figure this out? Mine started going off on it's own as well.
    Worried my neighbours will soon take a shotgun to the car.
    It's started last week and can't figure out what's causing it.
    I've got the '04 GT GFX sedan, completely stock, I don't even think I have the shock sensor unless it already came with the alarm.
    Does anyone know how to disable the alarm in the meantime??
    Thanks!
    Ray
    Jul 2004
    Just to give an update: I never figured it out but once I changed the battery, it never happened again ?!?!?!? strange indeed.
    Sep 2004
    Thanks for the update... I wonder if it's as simple as that.
    gotta find my second key fob and test that one out.
    thanks!
    Jul 2004
    Not the key fob battery, the car battery.
    Sep 2004
    Ahhh...
    haha thanks. That maybe what I need... I haven't done that yet.
    Thank you Mr. Sober lol
    Sep 2004
    Still having trouble with this, haven't had a chance to change out the car battery yet though.
    Does anyone know how to disable the alarm? i'm worried it's going to drive my neighbours nuts.
    And someone please remind me, when I lock the car key fob or not, does the alarm automatically arm itself??
    or is that only when i press the keyfob the second time?
    Is there a way to lock the car without the being alarm set/armed?
  1. Trunk triggering alarm
    By 3GFX in forum Problems with the Mazda3
    Last Post: 04-09-2009, 03:02 PM
