Results 1 to 15 of 15
Thread: Mazda 3 Sport stuck in park
    Jan 2010
    Default Mazda 3 Sport stuck in park
    I have a 2005 Mazda 3 Sport with under 50,000 km, automatic transmission.
    The stick is now stuck in park. I've tried the usual tricks, but it won't move. I was able to override this by putting a screwdriver in the override hole. The car drives fine, changes gears fine. The problem hasn't gone away after a few days. Anyone have any idea what's going on?
    Member Cosmo77's Avatar
    Feb 2005
    Behind You
    2012 F-350 6.7L
    Default Re: Mazda 3 Sport stuck in park
    are your brake lights working? Ie. is the brake switch working?
    Jr Member CanSpeed 3's Avatar
    Jun 2008
    Hmm my buddy's toyota did this. He said it was his key ignition. Something to do with the safty in the ignition. He smashed it a few times and it came loose. I dont suggest you try that, but its a good place to start looking at.
    __________________________________________________
    2004 M3 Sedan Titanium Grey- 5% Tint | LED interior | Fujita F5 CAI| 17" Ikon DTS| Magnaflow Exhaust | 8000k HID conversion | Kenstyle Grill | Smoked Side markers & Tails | Falken 912 205/50/R17 | Short Shifter | Leather GT Seats | Yellow Fogs | Hawk HPS | Skunk2 Springs | Next: Tranny mount
    Jan 2010
    I assumed it was the brake light switch so I took it in to canadian tire to get checked. The brake lights do not work.
    However, they said they checked the brake light switch and wiring and found no problem. They think it's some of the other wiring in the car, but that I would have to pay an additional $150 on top of the $75 I've paid just to have them investigate. I'm worried I'll end up spending $500 and get no results.
    Feb 2005
    Behind You
    2012 F-350 6.7L
    Quote Originally Posted by dave88 View Post
    so I took it in to canadian tire to get checked. .
    Well there's your problem
    Sr Member thanu31's Avatar
    2003 Honda S2000
    19 Post(s)
    i had a problem like this with my dads Sienna, and I ended up changing one of the fuses. Problem was solved.
    Forgot what fuse it is, but maybe you can check it out.
    Quote Originally Posted by Cosmo77 View Post
    +1 lol
    Past:
    2003 Protege5
    2007 Mazda3 GT
    2002 E46
    ///M
    2010 Mazdaspeed3
    2003 Honda S2000
    Current:
    2005 S2000
    Sr Member Thrizzl3's Avatar
    Jul 2008
    '18 Subaru WRX / '20 CX9
    265 Post(s)
    lol check the horn fuse..if its blown your brake lights won't work and you won't be able to shift out of park
    Quote Originally Posted by phil05gx View Post
    yep, I had the exact issue.
    Jan 2010
    Yeah, I got burned by cdn tire years ago, went in for an oil change for my Sunfire. It was cheaper to have them do the "checkup" with the oil change so I agreed. They tried to charge me $900 for a leaky brake line and new tires. The tires had at least 2 more years of driving on them, and the brake line was checked by 3 other mechanics who found no problem.
    They were telling me they thought it was the wiring with the horn and that's why they wanted to charge me more for them to look into it. Since a blown horn fuse can cause the problem, that could make sense. Hopefully they just need to solder the loose wire.
    I really doubt there is anything for them to solder. Swap the fuse, and you will likely be fine.
    Jr Member Skip's Avatar
    Jun 2007
    yep had the same issues on my car after i did some work on my tails. Definitely check the fuses for the horn and the tails..I was so worried when I couldn't get it out of Park as well. Goodluck
    2007 Black Mica GS Sedan
    Mods: 6000K Lowbeam| 3000K Fogs | VG Antenna | Open Mouth Grille | Chrome Door Sills | LED Tails/Third Brake Light/Sidemarkers | SSG Front Lip/Kenstyle Sides/Rear Flares | Nokya Yellows | Rota Torque | Eibach Prokits
    Jan 2010
    Problem fixed.
    Turned out it was corroded wires under the carpet. The wires run from the drivers side to the passengers side under the carpet. The carpet was damp, probably from our Canadian winters and that caused the wires to corrode.
    I'll definitely be more careful with getting the winter mats in as soon as the fall comes around and emptying the water when it builds up.
    I'm currently experiencing this problem right now (06, auto). It happened randomly the first few times but now the only way I can get it to shift out of park is by using the screwdriver in the override hole.
    The tail lights work fine but the brake lights don't come on at all. I don't see a fuse specifically for brake light, only tail lights and the fuses appear fine. The horn works fine as well. Any suggestions?
    129 Post(s)
    Quote Originally Posted by poundCake! View Post
    almost sounds like it could be the brake switch which would not be sending the signal to let the vehicle know its in park, which could also be why the brake lights are not coming on.
    Costco = good cheap solution
    It's like a buck a nut
    Sr Member schmat66's Avatar
    Pickering
    2006 Honda Civic Si
    159 Post(s)
    my truck had this problem and it was the pin in the tranny, wasnt expensive at all, the release pin or something
    DAI | XXR | NANKANG | DOMINANT ENGINERING | KW | BRIDE
    KAPTION | JVC | OPTIMA | INJEN | TRI POINT | NRG | AVENUE
    STRIPPING TECHNOLOGIES | EXCLUSIVE WHEEL AND TIRE | KAPTION
  1. comparing mazda 3 with mazda 3 sport
    By gfong in forum Buying a Mazda3
    Last Post: 11-10-2009, 08:30 PM
  2. Buying Mazda 3 sport - 04 or 07?
    By jannie in forum Buying a Mazda3
    Last Post: 11-24-2007, 07:33 PM
  3. Mazda 3 Door Lock Class Action Lawsuit
    By couch in forum Mazda3 General Discussion
    Last Post: 10-12-2007, 07:44 PM
  4. Best Price For Mazda 3 Sport GT
    By rad3 in forum Buying a Mazda3
    Last Post: 05-12-2005, 10:04 PM
  5. Recently purchased a Mazda 3 Sport GT
    By cstraw in forum Buying a Mazda3
    Last Post: 11-23-2004, 11:46 AM
