Results 1 to 7 of 7
Thread: MY MAZDA 3 IS STUCK IN PARK!
    May 2010
    Default MY MAZDA 3 IS STUCK IN PARK!
    My 2005 Mazda 3 is stuck in park. My brake lights are working, so it's not a blown fuse. If I stick a screwdriver in the shift lock it will work but otherwise it won't budge. Any idea what this can be? Would really appreciate the help guys. P.S> I Just Noticed My ENGINE LIGHT remains on while I'm driving, have no clue if this links to my Mazda being stuck in park.
    Feb 2010
    BMW F30 328i 6MT
    Default Re: MY MAZDA 3 IS STUCK IN PARK!
    I wouldn't be surprised if the CEL is on because of that...definitely take it to Jimmy at Street Performance or the dealership.
    Jul 2008
    Subaru WRX
    265 Post(s)
    how would he get it to the dealer if it doesnt leave park...? lol
    does the horn work?
    Uncle Ben
    Sep 2005
    37 Post(s)
    if the horn doesnt work then replace that fuse and it will work again. If that is not the problem then in order to get it mobile there should be a little plastic tab close by the shifter. Pop that tab up put the key in the hole. Shove the shifter in to nuetral remove the key put in ignition start the car and put the shifter in to drive.
    Most probable cause will either be the horn fuse as they are related to the brakes (dont ask why even i cannot answer that lol) or your nuetral safety switch is gone
    Edit: your engine light will not be on because of it (atleast never seen it one because of it)
    1991 Nissan Pathfinder SE-V6 Red/red interior - trade in
    2005 Mazda 3 GX ty grey/black interior - Write off
    2010 Mazda 3 GT E sedan Crystal White Pearl/on black interior- trade in
    2010 Speed 3 Crystal White Pearl/on black interior all options- current
    2007 Mazda 3 GS silver- current winter ride
    2002 BMW 330ci silver- new toy
    May 2010
    nevermind I brought it to the Mazda Dealership and they were at it for 4 hours and didn't even know what the problem was. When they finally called me they said it was a blown fuse and 3 of my brake lights were burned out. After I took it out of the dealership the stuck issue was fixed but my car felt as if it was IDLING really rough. 2 Days later my CAR WAS STUCK IN PARK AGAIN! FUSE BLEW OUT AGAIN! I bough some fuses at Canadian Tire for the temporary use of the gear shifter and brake lights but I have a feeling it's going to happen again. Is there a possibility of a shortage somewhere in the fuses?? IF I TAKE IT BACK TO THE DEALER are they going to fix it FREE OF CHARGE?!? It was only 2 days ago when I brought it in to get this issue fixed, so I'm gonna be real mad if I have to pay for them to fix it again. Thanks for all the comments so far guys, it's been real helpful
    May 2010
    & btw, where is Jimmy at Street Performance located?
    Uncle Ben
    Sep 2005
    37 Post(s)
    Seeing how you are blowing fuses it could be one or a combination of a few things
    Neutral safety is pooched backfeeding in the system or drawing to great amount of power popping the fuse
    there is a break in the brake light wire shorting to ground blowing the fuse
    there may be a break in your horn wire shorting to ground blowing the fuse
    PJB is bad
    Mazda did diagnosis found the fuse blown replacedit and you were off to the races. Now that diag is done and the roiginal problem was found. If you take it to the dealer it will be considered a comeback. That means that the car was in for repairs and left working and now is back for the same problem. dealer will diag it and in this case more then likely will recharge you as there is obviously a bigger problem at hand
  1. Mazda 3 Sport stuck in park
    By dave88 in forum Problems with the Mazda3
    Last Post: 01-30-2012, 12:00 AM
  2. Gum stuck in a floormat... help :(
    By m_bisson in forum Interior Styling & Appearance
    Last Post: 02-11-2010, 11:55 AM
  3. How do you park your Mazda?
    By mleblond in forum General Lounge
    Last Post: 02-11-2008, 03:08 PM
  4. Had anyone got stuck yet?
    By GGM3 in forum Mazda3 General Discussion
    Last Post: 12-29-2007, 07:49 PM
  5. BMW M3 GTR (H. Stuck @ Nurburgring)
    By Gizzmo_jr in forum Pictures and Videos
    Last Post: 05-28-2007, 02:54 PM
