I have a problem with my tires with feathering. I had alignment done by the dealer, but I'm not so confident that it will fix the problem. So far, I haven't seen improvements.
The feathering occurs in the rear. Is this caused by camber or by toe-in? Camber is not adjustable in the rear, and I noticed that according to the print-out from the dealer, I'm just outside of the permissible zone. He did fix the toe-in, though.
Is this common in our Mazda3? And why is my camber outside the permissible range if it's not adjustable?
Is the problem with tires? (They are a cheap tire from Taiwan, called Federal Tire).
