Results 1 to 19 of 19
Thread: Gouges in brake rotor!!
    Newbie Sparcas's Avatar
    Jul 2007
    Angry Gouges in brake rotor!!
    I had replaced my pads and rotors this winter and now i started to realize a slight clicking or squeal when i'm slowing to a stop. I originally thought the noise was coming from my drivers side, but upon further inspection, i noticed that there's gouges on my passenger side brake rotor!
    What do you guys think i should do - get a local mechanic friend to machine them or should i just fork out for a new set of pads AND rotors, again. (Since there still could be something in the pad causing the damage)
    I bought Raybestos + OEM(Magnum?) rotors last time...My only concern is my financial situation is less than flexible at the moment...
    2007 Mazda3 GT 2.3L / Fujita F5 CAI / KYB GR-2 Struts / LED Interior lighting / 8000K HIDs - 3000K Fogs / RAZO / 30% Lumar Ceramic Tint / LED 3rd Brake Light
    Sr Member Takumi616's Avatar
    Default Re: Gouges in brake rotor!!
    how many kim?
    2007 Crystal White Pearl Mazda 3 GT Sedan
    - 6K HID Headlights - 3K HID Fog Lights With Yellow Vinyl - KYB GR-2 - Eibach Pro-Kit - Eibach Camber Kit - K&N Typhoon SRI - Progress RSB - 35% Tinted Windows - RX-8 Rims with 18' Hankook EVO V12 - Vinyl Gloss Black Roof - GV Front Lip Kit - OEM Door Visors - Smoked LED Side & Rear Reflector - Blackout Emblems - Stubby Atenna - Hella Horn Supertones - PIAA Super Forza - Interior & Exterior LED Lighting - WeatherTech DigitalFit - Winter Tires Package -
    Jul 2007
    Since i last changed pads+rotors? Maybe 20K...
    get OEM rotors and pads, you can't go wrong with that.
    Jul 2007
    Would you, (or anyone) happen to know if the 04-05 rotors are the same for 07+? (2.3L) I found a local parts dealer that sells the FRONT OEM pads+rotors for $100!~
    http://cgi.ebay.ca/Mazda-3-2-3L-04-0...ts_Accessories
    Elite Auto Parts - Based in Scarborough - any opinions?
    Member mazdilla's Avatar
    Picton, ON
    You may have a caliper that's sticking. Check that too.
    Mazda ... gone zoom zoom!
    2012 Tacoma TRD Sport DCLB 'Lifted'/ 2008 Ford Escape Limited
    P.S. Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, 'The Light at the End of the Tunnel' has been turned off.
    Jul 2007
    it only makes the ticking noise when the brakes are applied 1/2 way and traveling at very low speeds(<10km). Otherwise, no noise... I think i'm safe... But thanks for the heads up! I'll make sure i check it.
    goodluck!
    Jul 2007
    Thanks!
    Official TM3 food tester froggy's Avatar
    Jan 2009
    yeah sounds like a piece of road debris got imbeded in your pads, or at least hung around for a while. If there's something stuck in your pad then it's obvious you've got to change it. The rotors you'll have to see how deep the gouge is and whether machining the rotor to get rid of the gouge will make the rotor to thin to be useable
    there's no such thing as too much zoom zoom
    Thanks to MazdaBetty for the avatar
    Quote Originally Posted by mazdabetty View Post
    OHHHHH I HATED IT when people used to steal my pole
    Jr Member Souls's Avatar
    Apr 2010
    Holodeck 12
    Quote Originally Posted by Sparcas View Post
    Quote Originally Posted by froggy View Post
    x2 this happened a couple of months ago on my wife's Ponitac Vibe, was stupid loud going thru Timmy's.... I popped the wheel off, cleaned the built up pad dust with brake disk spray, took my palm sander and 80grit, gave'er a good one then hit the pad till smoove = no more sqwealin'
    took maybe 10-15mins
    nice...
    Jul 2007
    aaaaaaaaaaaaaaaaaand - it's save to refinish the rotor with a palm sander?
    Member bluemazda3's Avatar
    Jul 2008
    Hamilton
    is your parking brake loose?? because mine is loose right now.. (going into QEW Mazda soon) and the calipers got stuck on my rotors and made a small gouge... might wanna look into that?
    2007 Mazda 3 GS Electric Blue
    Mods: 20% tints around, 17"Tenzo Type M flat black, VG Sharkfin Antenna, Eibach Prokit, Eibach Camber Kit, Vibrant STB, Angel Eyes, Axela Badge, Mazdaspeed Catback Exhaust, blacked out emblems, Nextmod front GV lip, Nextmod Rear Flares., 8000K HID, Aftermarket Fogs, Koni Yellows, Carbon Creations Carbon Fiber Hood.
    Apr 2010
    Holodeck 12
    Dude, you say that like I'd risk my wife and daughter lives, like I'm some kind of wannabe mechanic car noobie.
    it was just enough to take down the ridges on the rotor (and matching ridges on the pad). Don't forget the pad will re-wear (re-seat itself) back to the rotor anyways. taking down the ridges and cleaning the pad dust off, stopped the squealing for me.
    If you're really freaked by your grooves, I'm sure I saw a sign at PartSource that they machine rotors on site.
    Jul 2007
    I take everything with an 80 grit grain of salt.
    71 Post(s)
    Old school method!
    If it worked then it will work now. Unless you have money to spend, just replace them.
    Jul 2007
    Thanks Ry, I hear a couple of the guys here are using Magnum brakes. I'm looking at the OEM, rather than the slotted/cross drilled.
    71 Post(s)
    Talk to Joe (Flipdady) about some OEM blanks. I heard they went down in price quite a bit.
  1. Brake pad and rotor install!
    By dhawtin in forum Suspension & Brakes
    Last Post: 06-06-2009, 10:14 PM
  2. brake rotor thickness
    By victor_t in forum Suspension & Brakes
    Last Post: 04-14-2009, 07:29 PM
  3. Brake pads and rotor replacement ...where to go in TO/Markham?
    By user_nameless in forum Suspension & Brakes
    Last Post: 05-05-2008, 05:55 PM
  4. Need brake/rotor advice & help
    By SourcE in forum Suspension & Brakes
    Last Post: 03-16-2006, 03:43 PM
