Results 1 to 5 of 5
Thread: 205/55/16 vs 205/60/16
    Sep 2010
    Aurora, On
    Default 205/55/16 vs 205/60/16
    i just got a set 16" winter rim and now looking for tires for my 2010 mazda 3 GT. I was that for some tires the size 205/60/16 is cheaper, so i was wondering will these tires fit or should I forget about the 205/60/16 and just stick to 205/55/16
    Default Re: 205/55/16 vs 205/60/16
    It will fit but you speedo will be off
    Member Cosmo77's Avatar
    Feb 2005
    Behind You
    2012 F-350 6.7L
    It will fit, but like you said...cheaper
    Aug 2009
    Your speed will be a little slower. Uses this one for tire size calculator
    Tire Size Calculator
    Default
    205/60R16 is the size for a Speed3 and it's actually quite a bit bigger (I've seen both in person).
    Get the right size even if it's a bit more expensive.
