hey guys i change my transmission fluid and i used the right kind to amsoil etc. but now it makes noise or rubbing sounds everytime i turn in first gear. is it the lsd ? does anyone kno what the problem is thanks.
Probably is... Does it go away when the transmission warms up?
didnt really check but i will tomorrow. but i heard that the fulid takes time to blend or something like that. who knows if that true.
It's because the transmission and the limited slip diff use the same oil in the Speed3 so it's all about finding the right balance. Some people have added friction modifier to the transmission to get rid of the LSD noise but this may affect the shift quality so most of us just live with it.
This is well documented all over the place and everyone has said that it doesn't affect anything negatively.
thanks for the info i appreciate it! if you find anything else out or have other info please let me know
Start here: http://www.torontomazda3.ca/forum/sh...smission-Fluid
Then do a search, there should be tons of posts about this... I think there is one from Fobio about that noise as well.
