In the first picture, it's in the resting state. In the second picture, you're pushing towards the engine bay (sorry I'm using Paint to edit it, it might not look exactly like that but it should give you an idea).
Here's the diagram of the belt for 2008 Mazda 3:
"Auto Tensioner Pulley" is what I have in Green. As you can see, there are a lot of pulleys. You don't want to slide the belt off for the other pulleys.
Thanks for providing the illustrations
Do we have the inside schematic of the tension mechanism? How often does that fail vs the pulley itself?
____________________________________
2011 Celestial Mica Blue Mazda 3 GS Sport
2.5L 6 Speed Manual
DC Sports Intake, 5.5K Morimoto Retrofit HID kit, Sure Motorsports RMM
Enkei Wheels,R40 lug nuts, ISC N1 coilovers, Corksport short shifter, CS Rear sway bar
Ebay front strut bar, Custom magnaflow axleback w/ 4" tips, Style M front lip
I'm getting a noise whenever it rains or moist outside. Whenever I start up the next day it makes the following sound: http://soundcloud.com/user943064652/sets/es
Hope I'm in the right thread!
So I got the Gates pulley from Napa and changed it last week. Not too sure if my problem was really the pulley. Here are some sound clips:
http://soundcloud.com/user943064652/sets/engine-noise
004 is last night after a little rainfall.
005 is today when I went to the bank after work to do a deposit. When I got out of the car, that's the outrageous sound. Put the mic near the belts and pulleys. Help would be much appreciated!
This noise is a result of some problem with the belt and/or tensioner. My 2010 Mazda3 2.0 automatic had around 17k when I got tired of that sound and went to the dealer. At the 2nd attempt/visit I was able to re-produce the sound on the road. After that they put the car on the jack and heard it again. They decided to replace the belt and tensioner and the noise disappeared. Now the car has 30k and the noise is back again. I will ask them to replace these parts again. In my opinion the problem is caused by the tensioner, which has poor quality and... I was very surprised to learn that the wheel of the tensioner is made of plastic! How cheap are these guys at Mazda to save money this way!
Next car I am going to get after I sell or trade it won't be Mazda for sure.
Sorry, I posted before I read everything below. Thanks for advises. My car is still on the warranty till April 2013. I am thinking if I should go to Mazda and put the same original shit or order that Gates part and go to a mechanic. Where is that Jimmy @ SP you mentioned guys?
I bought the Gates pulley today at Napa and thinking about getting it installed by my mechanic.
To questions came into my mind:
1.Is there a chance that Mazda could refuse to fix the engine by the warranty, if something happens to it, like a damage caused by the belt cut?
2.What could be done to make Mazda recall their cars for pulley replacement to metal one? What is the procedure?
2004 Mazda3 Sport GT|Winning Blue| OG 2.3L @ 450,000 km & counting
I have 2010 Mazda bought in April 2010. The pulley was made of plastic. This winter Mazda replaced it with the same plastis pulley and the same belt. It worked 10.000km, then the noise came back.
Following the advises here, I bought Gates metal pulley and my mechanic replaced the original plastic one with it. Nothing has changed: well described here squeaking is still present.
Don't buy Gates part, won't help.
Just want to let you guys know that this has (temporarily at least) fixed my problem, using the Dayco 89015.
My problem was engine noise, almost like a diesel engine chugging sometimes with a whine between 1500-2000 RPM only under load when the gas is pressed. It was most obvious when the gear changes and the RPM dropped from 2500 to around 1700 at highway speeds. It also seemed to be worse the colder the temperature is.
I have a 2010 Mazda 3 sedan with 42500km on it and I noticed the sound around the 41k mark.
Thanks so much for posting it
For all of you guys not sure if the noise is coming from the pulley or the belt, here is a very simple way to tell which one is the culprit. With the car idling, grab a spray bottle and spray some water on the belt ribs. Just one or two squirts are enough. If it's the belt that's making the noise, it will stop, or at least the noise will change its character the moment you spray some water on it and will return after a short while when the water dries out. If the noise remains the same, chances are it’s the tensioner pulley or another accessory.
I'd give you the part numbers, but from what I heard, there's different belts for the different engine/year. You should also change the AC belt while you're at it because it has to be removed by removing the AC unit or cut the AC belt.
I have the same issue, I'm replacing the Serpentine and AC belts with Mazda OEM belts tomorrow at Street Performance. I'm hoping the sound will go away.
Have the same issue, my dealer told me "There is a sound coming from cooling system that sounds like a gurgling which is just the sound of coolant circulating back into overflow bottle."
Let me guess, you hear this noise also when driving uphill too?
I also had the serpentine belt, AC belt, and tensioner pulley replaced (dayco 89015) in February, the sound remained.
I don't think its the same, its pretty loud and whiney when its cold out. And relpacing the pulley made it go away for at least a little while.
Its that exact rpm range and accelerating that makes the sound not going up or down hills. If I put it in 2nd, put my e-brake on or my left foot on the brake and rev it to 1500 rmp the sound is clear as day. I'm probably making it sound worse than it is, I just don't like how my 2 year old car sounds like a 20 year old clunker when I drive down my street in the morning.
Update: So I got Jimmy to replace Serpentine and AC belts with Mazda OEM belts from MoT. It's tiny bit quieter, but the noise is still there. You can hear it at idle or low RPMs, especially when the hood is popped up.
Jimmy said it could because of a late oil change, something about clogging up the oil. He suggested trying better oil, like Pennzoil Platinum 5W20. I don't think that's the issue. I've always changed every 4 months give or take a few weeks.
I'll definitely try using Pennzoil Platinum next time as I bought some when it on sale at Walmart.
I'm out of ideas. Anyone else got an any ideas?
Thanks.
