horto
Time to figure out logging. Is there a better way to start datalogging with the DH, other than the following procedure listed in the manual? Ideally I'd like to just be able to hit "enter" from the monitoring screen before I hit an on-ramp.
Starting the Data Logger
START:
1. Press MENU to select MAIN MENU
2. Select Diagnostics and press ENTER
3. Select DataLogger Start and press ENTER
4. Select File Number to record
5. The DataLogger progress bar will indicate progress. The DataLogger will automatically stop when the capacity is full OR you can Press MENU (Repeat) to EXIT the current Display back to Start
I plan to log:
RPM, Boost/Vac, Load, FuelPressDI, Act AFR and Knock. Tips? Do I need actual TPS in there too? (max 6 params logging)
