[IMG]www.l3prime.com\images\IMGA0238.JPG[/IMG]
Here is a picture of the deformed fender washers clamping the aluminum shock mount into place. The picture understates how solid the mounting is. The tabs on the shock mount break off very close to the studs. What is left behind is a half inch of aluminum surface that is pinned between the deformed washer and the frame of the car. You know it occurs to me that since most of these shock mounts are probably going to break on a 8 to 10 year old Mazda that it might not be a bad idea to add a stainless steel or aluminum washer on to the top surface of one that has not broken yet. Adding a steel washer is going to weaken the mount over time because aluminum and steel react. Just a thought… If the failure of the part is inevitable, why not do something preventative.
