I have searched the internet endlessly and this forum site for the answer to this.
I'm hoping someone can help me out.
I have a 2004 Mazda 3 Sport 2.3 liter with 4spd AT
When I drive the car it makes a ticking sort of sound but only when I put my foot on the accelerator. There is like a sweet spot with the pedal where it makes the sound. If I go past a certain spot, it stops making the noise. Similarly if I let go of the gas pedal the sound goes away. It does it in every gear as long as I have the pedal at the sweet spot. It's very annoying since the sweet spot happens to be when I'm applying the gas just enough to cruise or maintain my speed.
If I have the car sitting at idle in neutral and I keep tapping the gas (going in and out of the sweet spot) the sound is there just not as noticeable as when it's driving in gear.
Is this a motor mount? Intake manifold valve? spun bearing? engine knock?
From what I understand it can't be an engine knock as it goes away during moderate to heavy acceleration and is only present during cruising speed (when the pedal is applied enough to maintain a constant speed). For example, when I'm cruising down the highway in 4th gear it makes the ticking sound. It is a constant tick that does seem to speed up or slow down depending on rpm's.
Please someone help me........
