Results 1 to 8 of 8
Thread: Wheel bearing whine , But wheel bearing's are fine, any ideas?
    Jr Member sol_searchin's Avatar
    Sep 2008
    Default Wheel bearing whine , But wheel bearing's are fine, any ideas?
    Just started yesterday, Driving on the 401 an idiot didn't kick the ice off his car, big ice chunk went under my car and made a thud/scrape sound. Now when i'm driving at about 40-50km/h i get this whine almost like a wheel bearing but I put it on a hoist today and inspected for play in the wheel's and there all solid! what the hell else could it be? ideas anyone?
    Edit: No vibration in the wheel, sound does not go away when turning.
    Jr Member Pokey's Avatar
    May 2010
    Default Re: Wheel bearing whine , But wheel bearing's are fine, any ideas?
    Drive shaft? When I first got my car I had to change a shaft that was starting to groan....
    Wes (ウェスリー) - Kitchener
    05 Sedan - Stock, Stock, Stock
    Sep 2008
    I hope not but totally possible this is more like a humming than a groan though almost sounds like a bad wheel bearing / loud tire's, when the car's good it's good when something happens a bunch of shit happens lol
    Sr Member Donutz's Avatar
    Dec 2005
    Possible damage to your plastic undertray. Damaged trays have been known to make all kinds of noises from whistling, whining, thumping, etc.
    Is not here
    Sep 2008
    the tray looks like it's hanging a bit lower, pretty sure last time i checked it was almost even with the filter housing peeking out from the sheild now its not visable. Anyone have a picture of what the front shield is suppose to look like?(been looking bu can't find one)
    Sr Member Zoom Zoom Boy's Avatar
    Aug 2008
    Quote Originally Posted by sol_searchin View Post
    - Courtesy of Unoriginalusername
    "Friends don't let friends, apex early."- unknown
    2008.5 Black Mica Mazdaspeed3
    2005 Titanium Grey, 5spd, GT Sport Hatch
    Sep 2008
    can't really tell, it's the rear by the filter that look's a little low i might have to remove it and see
    Sep 2008
    UPDATE: so i spent an some free time i had in checking out what the issue is. I put it on a hoist again, ran it up to 100km/hr and the thing felt like it was going to fall off the hoist! on the outside there was no visable movement (WTF right?) So i removed the rim's tire's and ran it again, same thing vibrations felt through the pedal's but only when the car is off the ground otherwise no vibrations felt when the car is driving on the road. Wheel bearing's are sound, fully inspected them and all 4 are in good shape. Transmission is good as the whining is heard when the car is out of gear. I'm running out of ideas, 2 last things to inspect are axle's and mount's - was told to look at mount's as a cause but would a failed mount cause a whining sound?
  1. Bad Wheel Bearing!! Help
    By mz3~Power in forum Problems with the Mazda3
    Last Post: 01-15-2011, 02:17 PM
  2. Wheel bearing?
    By alhope34 in forum MazdaSpeed 3 Forum
    Last Post: 07-10-2010, 12:32 AM
  3. How do you tell if wheel bearing is bad?
    By Shawn in forum Problems with the Mazda3
    Last Post: 07-05-2010, 11:11 PM
  4. aftermarket vs oem wheel hub assembly (wheel bearing)
    By silvermist99 in forum Engine & Drivetrain
    Last Post: 11-27-2009, 03:44 PM
  5. Wheel bearing
    By MAZDA Kitten in forum Problems with the Mazda3
    Last Post: 09-14-2008, 02:53 AM
