Results 1 to 6 of 6
Thread: How To: Programming auto door lock/unlock function (2010+ Only)
    73 Post(s)
    Default How To: Programming auto door lock/unlock function (2010+ Only)
    Located in section 3-37 of your user manual (2010+).
    Auto lock/unlock function
    WARNING
    Do not pull the inner handle on a front door:
    Pulling an inner handle on a front door while the vehicle is moving is dangerous. Passengers can fall out of the vehicle if a front door accidentally opens, which could result in death or serious injury.
    - When the vehicle speed exceeds 20 km/h (12 mph), all doors and the liftgate lock automatically.
    - When the ignition is switched off, all doors and the liftgate unlock automatically.
    These functions can also be disabled so that they do not operate.
    NOTE
    Additional auto lock/unlock function (Automatic transaxle)
    A function setting is also available which enable automatic locking and unlocking of doors and the liftgate when shifting gears.
    Refer to Personalization Features on page 10-9.
    Auto lock/unlock function setting change using door-lock switch
    The doors and the liftgate can set to lock or unlock automatically by selecting any one of the functions from the following list and using the driver's door-lock switch on the interior to perform the setting change as indicated in the procedure which follows.
    Function Number and it's Function
    1. The auto door-lock function is disabled.
    2. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more.
    3. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more. All the doors and the liftgate unlock when the ignition is switched from ON to ACC or Off.
    4. (Automatic transaxle vehicles only)
    When the ignition is switched ON and the shift lever is shifted from park (P) to any other gear position, all the doors and the liftgate lock automatically.
    5. (Automatic transaxle vehicles only)
    When the shift lever is shifted to park (P) while the ignition is switched ON, all the doors and the liftgate unlock automatically.
    Programming details
    1. Stop the vehicle and close all the doors.
    2. Switch the ignition ON.
    3. Press and hold the lock side of the driver's door-lock switch within 10 seconds of switching the ignition ON, and make sure a beep sound is heard about eight seconds afterwards.
    4. Referring to the auto lock/unlock function setting list, determine the function number for the desired setting and press the unlock side of the driver's door-lock switch only in the amount of the selected function number (Ex. If you select function 2, press the unlock side of the switch only 2 times).
    NOTE
    There are only a total of five auto lock/unlock settings available for automatic transaxle vehicles, and three for manual transaxle vehicles. Be sure to press the unlock side of the driver's door-lock switch the correct number of times according to the selected function number. If the switch is mistakenly pressed six times on an automatic transaxle vehicle or four times on a manual transaxle, the procedure will be invalidated. If this occurs, start the procedure from the beginning.
    5. Three seconds after the function setting has been changed, a beep sound will beep in the amount of the selected function number.
    NOTE
    - The doors cannot be locked or unlocked while the setting function is being performed.
    - The procedure can be cancelled by pressing the lock side of the driver's door-lock switch.
  2. The Following User Says Thank You to cwp_sedan For This Useful Post:
    geobur (06-27-2017)
  3. #2
    Jr Member crono06's Avatar
    Default Re: How To: Programming auto door lock/unlock function (2010+ Only)
    From my understanding, #3 seems the default from the factory?
    I don't like it that all the doors unlock when I shut off the ignition. So I guess I would select #2? I must take a look at the manual tonight.
    Alpine White 2013 BMW M Sport 335i xDrive
    CWP 2010 Mazda3 hatchback - Traded in
    Jr Member Pokaroo Kris's Avatar
    Nov 2011
    Edmonton
    Too bad this doesn't work for 04-09 models....or does it?
    If GM had kept up with technology like the computer industry has, we would all be driving $25 cars that got 1,000 MPG - Bill Gates
    Ontario
    2010 onwards have a module called the IDS. This allows for programming of convenience turn signal (3 clicks), switch on of Cruise control after the fact (already enabled before 2010) and the door lock functions. It's essentially the personalization features and pre 2010 doesn't have it in shop manual.
    Newbie NoMashMs3's Avatar
    May 2014
    Brampton Ontario
    hi
    25 Post(s)
    How do u program the 3 turn signal ?
    2013 Mazdaspeed 3
    Ontario
    Gotta go to the dealer. THis part of the computer is secured and can only be touched by Mazda.
  1. RFID Proximity Lock/Unlock
    By hzavery in forum Lighting, Electrical & Security
    Last Post: 02-14-2011, 10:32 AM
  2. 2010 Mazda 3 GS Unlock Trip Computer
    By bb147 in forum Mazda3 General Discussion
    Last Post: 08-04-2010, 05:24 PM
  3. Preference Programming for 2010 Mazda 3 GT
    By pjmodi in forum Mazda3 General Discussion
    Last Post: 05-31-2010, 07:29 PM
  4. $5 - UNLOCK Your cellphone with an unlock code.
    By htc*** in forum General Lounge
    Last Post: 09-09-2009, 11:13 AM
