Results 1 to 11 of 11
Thread: Need Rear Endlinks
    Jr Member JayJay18's Avatar
    Mar 2010
    Default Need Rear Endlinks
    Does anyone know of any good adjustable endlinks?
    My OEM ones are starting to come apart and its time for new ones?
    Member shu5892001's Avatar
    Default Re: Need Rear Endlinks
    Tri-point ones?
    Current: 2016 Lexus GS-F, 2017 Honda CRV Touring
    Past: 2015 Scion FRS 6MT, 2010 M3 E90 6MT, 2013 Scion FRS 6MT, 2005 Mazda 3 GT Hatch.
    Sr Member rzapata's Avatar
    Jan 2011
    Downtown TO
    36 Post(s)
    Quote Originally Posted by JayJay18 View Post
    How do you know if they're starting to fall apart? Pictures maybe? I just want to know how that would look...
    MajesticBlueNTO's Avatar
    May 2004
    49 Post(s)
    if you're not going to 1) track your car, or 2) use aftermarket adjustable end links to dial out pre-load, or 3) run a larger rear bar..then just go with OEM.
    if you do decide on Tri-Point rear endlinks, note that it doesn't have rubber bushings so you WILL hear clunking in the rear at times.
    Mar 2010
    Quote Originally Posted by MajesticBlueNTO View Post
    I forgot to mention I have hotchkis rear sway bar
    Jan 2011
    34 Post(s)
    my driver side one is making a clanking noise , so i bought a pair of oem endlinks off ebay 40 plus free shipping
    Jr Member Shawn's Avatar
    Nov 2007
    Is OEM good enough for Rear Sway bar (HotchKiss)?
    Anybody try these
    http://www.powergridinc.com/swaybar.asp
    Or These
    http://www.whiteline.com.au/do_segue...+1%2F04-9%2F09
    Regards
    Shawn
    Nov 2007
    Anybody put MazdaSpeed Rear links on their Mazda3 ?
    Sr Member Thrizzl3's Avatar
    Jul 2008
    '18 Subaru WRX / '20 CX9
    265 Post(s)
    wait jason..u need rears? i thought the noise was coming from the front...?
    Mar 2010
    Quote Originally Posted by phil05gx View Post
    my rears r fcked, the passenger rear it starting to come apart
    Nov 2007
    You can us OEM Mazdaspeed3 links. They will fit the HotchKis, but measure the hole in your bar to make sure.
    I just bought a set from MOT. They are 12M1.25 stud (beefer than MZ3) for the bar and 10M.1.5 for the control arm connection. Mazda ones do not come with the Nuts. . So you have to order separately.
    Or you can order Moog ones for Mazdaspeed3. They are about 10$ cheaper than Mazda and the have a bronze ball cup and have grease fittings. PN# K750069
    I hope I don't regret getting the Mazda ones.
  1. broken rear endlinks
    By lancesir in forum Suspension & Brakes
    Last Post: 09-22-2008, 12:14 PM
  2. Mazda3 vs. Mazdaspeed3 rear endlinks..is there a difference
    By azn_outlaw in forum Suspension & Brakes
    Last Post: 03-10-2008, 11:24 PM
