Results 1 to 10 of 10
Thread: 2010 & 2011 Mazda 3 HIDs may be an issue for all
    Jan 2011
    Default 2010 & 2011 Mazda 3 HIDs may be an issue for all
    Okay so i tried two different ballasts made by different companies and 3 different HID bulbs and 2 different relay harnesses
    What i noticed is that the passenger side will sometimes start up upon initial engine startup.. OR it will always start up if you start your engine first and then start your lights about 5-10 seconds afterwards..
    I believe this is because the ballasts require alot of power from the battery during initial startup and it's not getting enough juice because your alternator is always running... I always thought it was a ballast problem until recently. Why is it always the passenger side? I can't explain that yet.
    Now, with that said, it could also be the battery that may be defective and not providing enough juice.
    Don't worry mazda 3 2010/2011 folks!! just quit using the auto light function and remember to switch it to OFF before you leave the car so you won't look wierd with one working HID on the road.. That's if you experience this problem
    73 Post(s)
    Default Re: 2010 & 2011 Mazda 2 HIDs may be an issue for all
    First I'm confused. Mazda 2 or Mazda 3?
    This is a common problem with Mazda 3s and aftermarket HIDs. If you have initial firing problems that aren't hardware related issues, you have have to manually turn on (fire) the lights after you start the car.
    Member PR3Y11's Avatar
    Markham
    yes a little confusing but it's the first i'm hearing of this problem...i always leave my lights on auto and have never had any issues
    Jan 2011
    woopss!! I meant Mazda 2s..
    73 Post(s)
    Maybe you should post it here to help allow TM2 to grow.
    http://www.torontomazda2.ca
    Jan 2011
    Wow, there was something wrong with the netbook I was using.. The 3 key is a 2... And the 2 is a 2 as well.
    This is so stupid.. LOL..
    Okay so my final answer is 3..
    73 Post(s)
    Default Re: 2010 & 2011 Mazda 3 HIDs may be an issue for all
    So much fail! Fixed earlier posts lol
    Member bluemazda3's Avatar
    Jul 2008
    Hamilton
    keyboard fail....
    2007 Mazda 3 GS Electric Blue
    Mods: 20% tints around, 17"Tenzo Type M flat black, VG Sharkfin Antenna, Eibach Prokit, Eibach Camber Kit, Vibrant STB, Angel Eyes, Axela Badge, Mazdaspeed Catback Exhaust, blacked out emblems, Nextmod front GV lip, Nextmod Rear Flares., 8000K HID, Aftermarket Fogs, Koni Yellows, Carbon Creations Carbon Fiber Hood.
    Jan 2011
    Quote Originally Posted by PR3Y11 View Post
    +1
    Dec 2009
    I have never hear of these issues with any quality after market H.I.D kit that are installed correctly using the supplies 2 wiring harnesses that draw from the battery. Are you guys leaving your DRL's hooked up when your supposed to disconnect them if it uses the same low beam the H.I.D bulb will. I know the harness only uses the factory headlight plug as a trigger to then draw power from battery. Mazda 3's must use park light for trigger not the harness to the factory bulb as DRL's do not supply 12v.
    http://www.kbcarstuff.com/HID-Kits-s/216.htm
    Talk to them regarding your vehicle and specifics
  1. 2011 Mazdaspeed 3 versus 2011 Mazda 3 GT ride height
    By rocketlow in forum Suspension & Brakes
    Last Post: 07-22-2011, 10:59 AM
  2. How to adjust the HIDs in 2010 mazda 3
    By mikeball in forum Lighting, Electrical & Security
    Last Post: 03-07-2010, 06:02 PM
