Results 1 to 25 of 26
Thread: aDyno for Android - Discussions and Results
    Sr Member stevenma188's Avatar
    Aug 2009
    Edmonton
    Default aDyno for Android - Discussions and Results
    So I found an app on the Android Marketplace that dyno's your car based on the accelerometers in your phone. Link Here: https://market.android.com/details?i...W5vLmFkeW5vIl0.
    The program has a lot of settings and parameters. So far, I've left everything default, except the weight of the car (which I found off wikipedia).
    My result: 158.2HP and 152.6ft/lbs torque
    Now I know this is not accurate as a real dyno, but it's free.
    Wondering what other people are getting, and also if anyone has insight on what to set the parameters to to obtain more accurate results, please share.
    CURRENT: 2008 Subaru Impreza STI | 1986 BMW 325 5.0L V8 Swap | 2006 Dodge Ram 1500 | 2004 Ford F-350 | 1993 Toyota 4Runner | 2003 BMW 325i | 1991 BMW 325i
    GONE: 2005 Mazda 3 Sport GS | 1998 BMW 328i | 1992 Mazda Miata | 1986 BMW 325e | 2000 BMW 323ci | 2003 Dodge Ram 1500 | 1999 Volvo S70 AWD | 1986 BMW 325es | 2002 BMW X5 4.4i | 1998 Mitsubishi Evo V
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    250 Post(s)
    Default Re: aDyno for Android - Discussions and Results
    downloading now
    Sponsor Aitch's Avatar
    Jan 2005
    San Diego
    '98 BMW 750iL
    299 Post(s)
    Also downloading, will report back eventually.
    Hyperion's Avatar
    250 Post(s)
    Downloaded like 3 minutes before, works pretty good.
    You can find the stats for your car here
    Member Zuluwun's Avatar
    5 Post(s)
    hm, "dynolicious" seems to be the apple dyno app of choice. I'll give it a shot sometime and see what it comes up with.
    Jr Member Kessly Snipes's Avatar
    Jan 2012
    Quote Originally Posted by Zuluwun View Post
    And it is very accurate
    I forgot to turn of DSG etc and it was a bit wet, bad combo. but 400 HP, lol.
    Aug 2009
    Edmonton
    474HP...sure...accurate....
    Jan 2005
    San Diego
    '98 BMW 750iL
    299 Post(s)
    That's accurate....... if you have enough stickers on your car.
    Feb 2010
    BMW F30 328i 6MT
    19 second 0-100 @ 400hp is accurate?
    Our definitions of the term "accuracy" must be totally different...LOL.
    --- CURRENT - 2012 BMW 328i 6MT :: White on Red ---
    --- OLD - 2006 Mazda3 GT GFX 5MT :: Black on Black ---
    Jan 2012
    It also appears that sarcasm is a foreign language here...
    Hyperion's Avatar
    250 Post(s)
    Default
    Quote Originally Posted by Kessly Snipes View Post
    Don't be fooled, we all speak fluent sarcasm
    Sent from my HTC Sensation XE with Beats Audio using Tapatalk
    Aug 2009
    Edmonton
    Hyperion and Aitch: Any results yet?
    Jan 2005
    San Diego
    '98 BMW 750iL
    299 Post(s)
    Default
    Sorry, haven't really had my car out yet.
    Member loosecannon's Avatar
    Jul 2009
    Markham
    Streetcar
    The app says to drive in one gear from 1,500 rpm to redline. I'm assuming 3rd would be the optimal choice?
    Hyperion's Avatar
    250 Post(s)
    So far:
    First gear from dead stop to 6400 rpm's ish. Why it only recorded to 3200 I"ll never know. Will try again tmo.
    This was uncalibrated. As I downloaded 2 minutes before work.
    This was also with my phone being held in my hand. Will mount it once I find my mount lol.
    Sr Member Kiyomi's Avatar
    116 Post(s)
    this app looks like bs...
    Sponsor
    Lockdown's Avatar
    Oct 2011
    5 Post(s)
    If these are anything like a GTech, they can be very accurate but take a long time to dial in and you will never really know until you actually have a dyno and some quarter mile times. I have my Gtech Pro SS dialed in within 1/10 of a second in the 1/4 and within about 2% or 15hp on my stang. It takes a lot of time to get these accurate though and if it's not really close to accurate its kind of useless unless you are just trying to find gains from a baseline but even then, percentages can be off and the calculations go out the window.
    Phone: 647-439-4485
    AUDIO | SECURITY | ACCESSORIES | HID & LED LIGHTING | VIDEO & MULTIMEDIA | ELECTRICAL DIAGNOSIS
    Aug 2009
    Edmonton
    Quote Originally Posted by loosecannon View Post
    You can set it up to dyno any gear you want, you just have to set the corresponding max and min speed. Defaults are designed for 2nd gear.
    The reason your reading is so off is because you used first.
    What you are suppose to do is at a standstill, hit Start on the app. Once it's done calibrating (it will beep), start in first. Shift into 2nd at around 2500-3000RPM. Once you are in 2nd, (you want to be around 2000 RPM by default - minimum RPM in the settings), take it all the way to 6500RPM (max rpm in the settings).
    Also, I just place my phone in the cupholder, with the screen facing rearwards. I notice the phone cannot be completely vertical either, so the cupholder works well.
    Hyperion's Avatar
    250 Post(s)
    Well then, I'll give it a shot tonight.
    Edit. Gave it a shot. Went from 1st to 2nd. I think I have a bit more calibrating to do
    It looked pretty legit until the 184 spike.
    Moderator p-o-g-i's Avatar
    'ssauga
    84 Post(s)
    I just downloaded it for $hits and giggles...... will be fun to play with.
    resident "Bouncer"; all-around nice guy ...
    Aug 2009
    Edmonton
    Here's my 2 Dyno graphs, taken on 2 different days:
    Got 143HP on the 2nd run. Can't remember the torque. Had to clear the data cache because for 1 pull, I guess I didn't hit the brakes hard enough at the end, so ended up logging like 15 min of driving around, which caused the app to crash.
    Aug 2009
    Edmonton
    Did another pull this morning. this thing is pretty consistent.
    Hyperion's Avatar
    250 Post(s)
    Quote Originally Posted by stevenma188 View Post
    Where did you get all your stats?
    I'm missing a few things.
    Aug 2009
    Edmonton
    What stats are you missing? All I chaged was weight, left everything else default.
    Jan 2012
    I'm not sure about with the app, but you will have less power to the ground in 1st. There is a reason they do most dyno runs in 3rd.
  1. Android
    By PCLoadLetter in forum General Lounge
    Last Post: 09-11-2011, 07:52 PM
  2. Android People...UNITE!
    By starscream in forum General Lounge
    Last Post: 11-01-2010, 10:39 AM
  3. Cobb Discussions
    By Fobio in forum MazdaSpeed 3 Forum
    Last Post: 05-08-2008, 01:29 PM
