Results 1 to 15 of 15
Thread: MS3: Baro & Temp Data for Toronto
    Fobio's Avatar
    173 Post(s)
    Lightbulb MS3: Baro & Temp Data for Toronto
    As discussed in today's Tuning Seminar, we have a reliable resource for weather data in Toronto to apply proper SAE correction to Vitual Dyno plots:
    Toronto's past 24 hrs readings (this is a consolidated page with all data)
    LINK: Toronto Island Weather over the Last 24 Hours
    Barometric Pressure Converter [from Kpa to in/Hg]
    LINK: Barometric Pressure Converter
    Temperature Converter [C* to F*]
    LINK: Temperature Converter
    Moderator Mr Wilson's Avatar
    Jan 2010
    227 Post(s)
    Default Re: MS3: Baro & Temp Data for Toronto
    Thanks Fobio.
    0.000212524463 gigawatts
    Sr Member dentinger's Avatar
    May 2007
    Edmonton, AB
    12 Post(s)
    i dont see how Baro and Temp is THAT critical for tuning.
    Baro/atmospheric pressue will always be about the same, would it not? you're at sea level in toronto, so you wouldnt see any real difference no?
    I guess I should also rename the Engine/Drivetrain section "Arts & Crafts"
    2007 Mazda3 gx
    2003 Volkswagen GTI 20th Anniversary Edition
    2010 Kawasaki Ninja 250R
    2011 Dodge Ram 1500 Outdoorsman / 2012 Ducati Monster 796
    MajesticBlueNTO's Avatar
    May 2004
    49 Post(s)
    Quote Originally Posted by dentinger View Post
    there are some things that people know and there are some things that people don't know.
    usually, when people don't know, they don't form a question as if they know the answer then ask for the answer.
    May 2007
    Edmonton, AB
    12 Post(s)
    im not familiar with dyno tuning cars (re: not at all)
    i know the MAP sensor/BARO sensor/IAT sensor gives pressure/temps inputs, but is it different when tuning?
    Fobio's Avatar
    173 Post(s)
    In our Tuning Seminar today, we discussed using Virtual Dyno [a program that turns our datalogs into usable and reliable dyno plots that when appropriate correction factors are used] and how it can be very useful as a tool in gauging our individual tuning progress. And as a tool, you want to increase its accuracy as much as possible, hence the SAE correction factors for all to use here.
    The data is to be used for SAE correction. We do not use the data to "tune", but we use the data to apply a standardized Society of Automotive Engineers' "correction factor" due to differences in temperature and barometric pressures to ensure the numbers that are generated from logs are genuine, or as genuine as possible in accordance to a generally accepted standard. In short, it keeps our dyno plots honest, usable between different cars on different days.
    And to answer your original question, barometric pressure and its fluctuations DO make observable and enough of a difference. You would have to have played with it to see it tho...
    Member fywdyl's Avatar
    The Weather Network website works too if you want to be more specific with the city. You'll have to use the Last 24-hr screen to find baro thou.
    Fobio's Avatar
    173 Post(s)
    I've tried that too...but I find the info harder to get at...takes longer. The above site has all info on 1-page and it also offers different cities too.
    Oh sweet, I just noticed that it does. Thanks Fobio!
    Sr Member boyracer's Avatar
    NATOR T.O. Outpost
    Vapour Trail
    117 Post(s)
    Thanks for the links Fobio
    Member Snotrocket's Avatar
    May 2010
    Peterborough
    34 Post(s)
    should humidex be considered?
    Hole In Block Tuning! I'll give you HIB.
    2010 MS3 Black
    395whp/386wtq
    | Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning CO's | stoptech breaks and slotted roters |
    Fobio's Avatar
    173 Post(s)
    Quote Originally Posted by Snotrocket View Post
    Most dyno's do take that into consideration, but VD doesn't have a spot to input that.
    May 2010
    Peterborough
    34 Post(s)
    Default
    I see. But what about if the temp is 28 degrees but 35 with the humidex you could just put in the 35? Or would that be inaccurate.?.
    Fobio's Avatar
    173 Post(s)
    Humidex, like wind chill factor, is just a way to tell ppl how the weather "feels" on the skin. Those do not apply to ambient temp, which is what SAE correction is about.
    Fobio's Avatar
    173 Post(s)
    For those that use Virtual Dyno, who choose to use a 1.01 correction factor rather than entering baro and temps for SAE correction.
    Fact: 1.01 CF is just a quick and dirty way on VD to *APPROXIMATE* SAE correction. These correction factors were also used by guys in higher elevations [read: Colorado, for example] to *APPROXIMATE* sea-level. 1.01 CF on VD is by no means a "standard".
  16. The Following User Says Thank You to Fobio For This Useful Post:
    MS3Edge (06-26-2014)
  1. Toronto MS3 Sightings
    By spd frk in forum MazdaSpeed 3 Forum
    Last Post: 09-03-2009, 11:07 AM
  2. C&D Mazdasped 3 data test sheet
    By Unoriginalusername in forum Mazda3 General Discussion
    Last Post: 05-22-2007, 03:20 PM
  3. Toronto Star MS3 Review
    By WildEmu in forum General Lounge
    Last Post: 04-10-2007, 11:27 AM
  4. Mazdaspeed Oil temp & Pressure Gauges install
    By MPS in forum Performance
    Last Post: 02-22-2007, 01:29 PM
  5. Mirror Homelink Auto-Dimming W/Compass & Temp 2004 Mazda 3
    By SCORPION6 in forum Lighting, Electrical & Security
    Last Post: 03-13-2006, 12:41 PM
