Results 1 to 19 of 19
Thread: MS3 Spin on Oil Filter conversion - Pro tips
    Newbie png's Avatar
    Mar 2012
    Post MS3 Spin on Oil Filter conversion - Pro tips
    I've recently put on the spin on oil filter conversion for the ms3 and wanted to share some tips for others who are jumping on this bandwagon.
    The main benefit of doing this mod is to have an easier time changing the oil filter. You'll be saving time by not having to change two o-rings and messing with a plastic housing piece everytime you change your oil. Another benefit is that you can run larger filters. So IMO, its mainly a convenience mod and is totally worth it if you're doing your own oil changes.
    Technically speaking this is a straight forward mod to do, but the tight space makes it kinda difficult. This is intended to be an addition to the tutorials already out there for the ms3. You can just google them.
    -To remove the oil sensor wire, use a screwdriver to push in on the tab on the side of the sensor. In my case the tab was facing up and away from me so I used a little mirror to get a better look. Get this out of the way as you dont want to cut the wire. It's also a good time to loosen the bolt holding the sensor. Just be careful with it.
    -The ms3 has an oil cooler which means that you have to unbolt it to remove the stock piece. Loosen the oil cooler bolt BEFORE removing the stock housing. You wont be able to get proper torque on the bolt unless the piece is on the car. This is the HARDEST part of doing this mod. The vertical bolt is located above the filter housing and is surrounded by coolant hoses. It's a very tight space, so one way around this is to partially unbolt the 4 horizontal bolts to give yourself more room. This worked like a charm for me. An angled ratchet wrench was helpful too.
    -DO NOT DISCONNECT the coolant hoses. These are the black hoses that go to the oil cooler and can stay connected for this install.
    -Retighten the four bolts in a criss cross pattern so that the plate goes on evenly.
    Hopefully this will save you guys some time and headache. I got the kit from Flipdaddy at MoT.
    Moderator loki's Avatar
    881 Post(s)
    Default Re: MS3 Spin on Oil Filter conversion - Pro tips
    how much was the kit?
    need this kit for those who want to run oil pressure and oil temp. gauges.
    Member fywdyl's Avatar
    On SU it's $89, but I think you can get one from a Mazda dealership.
    Newbie png's Avatar
    Mar 2012
    The kit was 91$ + tax from Mazda of Toronto. It came with the spin on filter housing, gasket, filter cartridge, and oil drain washer.
    Member breakfasteatre's Avatar
    Jan 2011
    35 Post(s)
    poo a thousand, won zero
    Oh damn, that sucks. Oh well, I stopped reading the Speed section because according to certain people only speed owners are allowed to even look at that section.
    Newbie Addison's Avatar
    Apr 2010
    Seriously? fack.
    07 Mazdaspeed 3
    881 Post(s)
    Quote Originally Posted by Addison View Post
    Seriously? fack.
    yes. you need the spin on conversion kit, which according to a few of the guys here will run you just under 100 bucks from one of the affiliate dealers, plus you need the sandwhich plate
    Apr 2010
    I've got some more reading to do.
    Jr Member joedemarco's Avatar
    Jul 2011
    Bolton, Ontario
    any reviews on this? was thinking about doing it and start doing my own oil changes...Addison, were you able to find any other info!?
    Easy formula to remember for success when modding your car..
    no wife + no kids = no problems.
    73 Post(s)
    Quote Originally Posted by joedemarco View Post
    What do you mean reviews? It's an OEM application so why would you need a review on it? People change to this application to make oil changes easier as well as adding the sandwich plate for additional gauges.
    If either of these are what you are looking to do then that's all you need to know.
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Ban jdm. Lol
    Member standsideways's Avatar
    Jan 2010
    5 Post(s)
    Default
    Ban jdm. Lol
    Lol seriously tho, its a stupidly easy istall, no review needed, if you want a spin on over the cartridge, do it.
    Jan 2010
    5 Post(s)
    Default
    Fyi i payed less than $60 for mine at forbes waterloo mazda
    CelestSpeed3's Avatar
    Aug 2005
    Vaughan
    48 Post(s)
    You can pay half that and just get the service tool to change the cartridges properly as well.
    Want to work on your car but not sure how, send me a PM. Learn the way of Nator.
    Newbie Atomic's Avatar
    Jul 2009
    Do you have the part number for the spin oil kit for mazdaspeed3 gen1 ?
    It will be very helpful to help my mazda dealer here ...
    all you need to know is here: http://www.protegefaq.net/mzroilcooler/
    Jr Member JSharrmz's Avatar
    Jul 2012
    Newmarket
    2008 BMW 323i
    12 Post(s)
    What's all this talk about a "kit" all I did was get a prosport adapter plate (sandwich) that bolts onto where the cartridge bolts into and the spin on is spun underneath .. Whys everyone buying these expensive ass kits that essentially does the same as a 40$ -/+ prosport product, don't get it
    Photobucket Pictures, Images and Photos
  18. The Following User Says Thank You to JSharrmz For This Useful Post:
    fruitloops (02-25-2014)
  19. #18
    Member mikey32235's Avatar
    Jul 2012
    Quote Originally Posted by JSharrmz View Post
    really? read the difference between a paper and spin on filter.
    Forged - Overbore - BNR S3 Turbo - Meth -
    *** Tuned 348whp/414wtq
    Stratified tuning currently… Numbers coming soon
  20. #19
    Jul 2012
    Newmarket
    2008 BMW 323i
    12 Post(s)
    I know the difference , I was just confused.. I was told the adapter plate was all I needed and I now know I need the housing as well.
  1. 2010 MS3 oil filter... is a spin-on?
    By Elusivellama in forum MazdaSpeed 3 Forum
    Last Post: 01-04-2011, 05:17 PM
  2. Spin-On Oil Filter Adaptor/Conversion
    By starscream in forum MazdaSpeed 3 Forum
    Last Post: 10-28-2009, 03:16 PM
