Results 1 to 16 of 16
Thread: Checking oil in a 2012 Mazdaspeed 3
    Default Checking oil in a 2012 Mazdaspeed 3
    Hi Guys,
    When do you check the oil to determine if its ok. Is it
    1. First thing in the morning (when the car has overnighted)
    2. After a 5-10 minute run or idel
    I ask because at first thing in the morning (when the car has overnighted) the oil reads just at the minimum mark. This kind scares me
    However after a 5-10 minute run or idel the oil reads max.
    Not sure.
    My car has 2500kms on it and this is how i got it from the dealer.
    Please assist
    Default Re: Checking oil in a 2012 Mazdaspeed 3
    This may be stupid, but you're checking on level ground too right?
    Sr Member stevenma188's Avatar
    Aug 2009
    Edmonton
    You are wiping the dipstick, putting it back in, then reading that level right?
    CURRENT: 1986 BMW 325es | 2003 Dodge Ram 1500
    GONE: 2005 Mazda 3 Sport GS | 1998 BMW 328i | 1992 Mazda Miata | 1986 BMW 325e
    Member Booostin's Avatar
    May 2011
    Your Mom
    I read my oil in the morning after car has been sitting so the oil gets a chance to settle.
    engine oil = cold
    tranny fliud = warm
    Sr Member Thrizzl3's Avatar
    Jul 2008
    LOL!
    OP are you seriously saying you don't know how to check the oil?
    yep, level ground
    Quote Originally Posted by Thrizzl3 View Post
    LOL!
    Don't be a dick. Some people may not know but I think there is more to it in this case.
    - Park car on level ground.
    - Let car sit for 10+ minutes. (After driving or over night. Doesn't matter)
    - Pull out dipstick and wipe off oil marking. Don't bother reading the level.
    - Re-insert dipstick, wait 3 seconds and pull out dipstick again.
    - Read oil level.
    CelestSpeed3's Avatar
    Aug 2005
    Vaughan
    When the car is parked and cooled off sometimes there will be a small amount of pressure om the dipstick tube. This pressure will force the oil lower on the stick giving a false reading. Follow the instructions Bluestreak posted will give you a proper oil reading.
    Want to work on your car but not sure how, send me a PM. Learn the way of Nator.
    Jr Member Nova 3 GT's Avatar
    Oct 2007
    Trois-Rivieres, QC
    - Read oil level.
    I heard that the best time to check the oil is when you go fill up. Gas stations are always leveled and correct me if I'm wrong on this but checking the oil after the car has been overnighted might give you a false reading because the oil has time to run down from the valves and lifters and it might show up as slightly overfilled.
    馬自達 3 Sport GT 2006 - 27A
    CX-7 stubby - Axela badge - MS CAI - LED 3rd Brake Light - Full LED flasher conversion
    Quote Originally Posted by Nova 3 GT View Post
    That is completely false...It is always better to check the oil after the car has been sitting. The longer the better. Overnight is perfect. But make sure you are on LEVEL ground. Check it twice!!
    2005 Indigo Blue Sport GT~MS CAI~Vibrant Exhaust~Vibrant Sway~Eibach ProKits~Progress SB~18"ADR FIN7's~TWM SS~MS Pedals~Stubby~20% Tint~JDM Rainguards~OEM LED Tails~WeatherTech mats~Angel Eyes~AudioSystem; JL-VR650Csi~JL-VR659CX~JL ProWedge 10W6v2~JL CleanSweep~RockfordFosgate Punch Amps 900W true RMS~Stinger Cap & Amp Kit~Protected by KROWN and still rust free
    Member PR3Y11's Avatar
    Markham
    yay red ranger
    Jr Member Sean80's Avatar
    Jan 2007
    At least he checks his oil. I'm sure many of us don't check it as often as we should.
    Quote Originally Posted by Sean80 View Post
    Your probably right, but then how much better is it to check the oil regularly, if your not checking it correctly? ;-)
    I would guess one problem is, it's not easy to remember to check your oil before you get going in the morning, so I would say the best time is when you go fill with gas. But wait till you've filled the car, maybe cleaned the windshield then check the level. This allows most of the oil to get down to the pan giving you a better reading. But as I stated before always check twice. It's also a good time to eyeball other things like belts etc; ...my 2c
    thanks guys, worried for nothing, u all were right, i wiped it and checked it twice, three times. All is ok
    Jun 2011
    Ottawa
    yay for healthy Pu!
    -- Black Mica Mazdaspeed 3 --
    STOCK FTW ... well because warranty
  1. 2012 Amsoil Oil Filter
    By shutterbug in forum Engine & Drivetrain
    Last Post: 01-14-2012, 01:43 PM
  2. 2012 Mazdaspeed 3 Specs
    By rzapata in forum Mazda3 General Discussion
    Last Post: 11-05-2011, 03:22 PM
  3. Checking the oil filter casing?
    By maoro in forum Engine & Drivetrain
    Last Post: 02-01-2009, 12:36 PM
  4. Need Help: Oil for Mazdaspeed
    By mleblond in forum MazdaSpeed 3 Forum
    Last Post: 03-29-2008, 11:37 AM
  5. Mazdaspeed oil caps
    By FLIPDADY in forum Engine & Drivetrain
    Last Post: 11-16-2004, 01:48 AM
