Results 1 to 25 of 40
Thread: 1-2 shift grind
    Newbie Sappo569's Avatar
    Apr 2012
    Etobicoke
    Default 1-2 shift grind
    Let me just pre-face by saying I've been driving manual vehicles since I learned how to drive (12 years)
    I've noticed the 1->2 shift on my transmission is hard to land 100% quickly, without grinding.
    Normal driving sure its fine, but when its a quick 1-2 with boost kicking in, I often times find its almost as if the gear is caught just before it drops in, meaning my clutch foot is already coming back up = grind.
    I might have to modify my shifts, but I'm just used to being able to drop it into 2nd and slip the clutch no problem
    Is this something the aftermarket clutch plate would help to alleviate?
    It looks bad when launching and all you can hear is the grind
    Shoot, Move, Communicate
    Member fywdyl's Avatar
    Default Re: 1-2 shift grind
    Driver mod needed...
    J/k, a lot of us MS3 guys have switched over to ford trans fluid and it helps a lot.
    that's what she said...
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    switch fluid.....if doesnt do the trick your faccckkkked........the synchros are gone.........hope you gots warranty........
    Apr 2012
    Etobicoke
    Thanks guys, will check into the tranny fluid.
    Warranty check, but I doubt its that bad... I think its 50/50 on me rushing the clutch before the gear is engaged, and switching out the fluid
    Jr Member horto's Avatar
    Aug 2009
    16 Post(s)
    Oh shit, I forgot I had 3 bottles of this stuff stashed away from the last GB!
    Also, aftermarket rear motor mount solves this problem.
    Apr 2012
    Etobicoke
    Is it really that wide-spread a problem?
    Also there is no 'one' fix it appears?
    I was watching the Jbarone video where he adjusts the shift cable too, and it looks like the same sort of issue... Either 1-2 is stiff, or 5-6 is stiff.
    In my case 5-6 is stiff, but 1-2 just doesn't wanna go in when WOT
    So what we talking, Transmission fluid, RMM, Shift plate?
    All of the above...?
    Apr 2012
    Etobicoke
    While doing more 'searching'
    http://www.torontomazda3.ca/forum/sh...fter-Adjusting
    This thread seems to be the same problem I've been having, complaints of 1-2 being hard to engage and 'grindy'
    I will try the adjustments (same as the JBarone video) this weekend and post results
    Member Cab0oze's Avatar
    Nov 2009
    Montreal :(
    18 Post(s)
    I just replaced the OEM rubber shifter bushing crap with washers for 1$ and it made a world of difference. Then I tuned the selector rod as per the Jbarone vid and that took 2 seconds and made an additional slight positive difference.
    I haven't had gridning in any gear now except for the occasional grind when going back to first gear at a slow roll. (or course this will likely change when the temp goes back below zero...)
    I am tempted to change the transmission fluid, BUT i feel like that would be stupid until im out of warranty (because I'm thinking in the next year i could probably get my transmission fixed under warranty, and I dont want to see my expensive new fluid just flushed back out in a year.)
    Canada gave us rust and DRL. Thanks for nothing Canada!
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Quote Originally Posted by Cab0oze View Post
    Don't be cheap bro. lol
    Member mazdaspeedemon3's Avatar
    Nov 2011
    Hamilton/St. Kitts
    Changing the transmission fluid to that ford shit wouldn't void warranty, would it?
    Mazdaspeedemon3's Ride
    yo, i update my sig everyday with other peoples comments. son
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Quote Originally Posted by mazdaspeedemon3 View Post
    No, even mazda uses the shit but they will charge you 250 for the service. faccckkk mazda.
    295 Post(s)
    $250 to drain and fill tranny fluid? Seriously? If they can do an oil change for $50, they should be able to do tranny fluid for under $100.
    - 2021 Porsche Macan GTS -
    Member mikey32235's Avatar
    Jul 2012
    i don't have a 1st to 2nd grind, but a lot of times when i accelerate from 2nd to 3rd quickly, 50% of the time i will get a grind. how do i fix this? what could it be? HELP!
    Apr 2012
    Etobicoke
    Quote Originally Posted by mikey32235 View Post
    Probably more of the same issues , and fixes posted.
    I am going to try the cable adjustment this weekend, and see how much of a difference that makes.
    Would change my own tranny fluid, depending on how hard it is, and if i can do it in my parking lot (without jack stands or anything)
    Jr Member Pereira11's Avatar
    Sep 2008
    Oakville
    Honda S2000
    do a slave cylinder drain and fill (uses brake fluid). recently did it on my own car (S2000 using Mazda Dot 4 fluid) and also changed the transmission fluid (GM Syncromesh). My grind went away and everything feels brand new again
    Apr 2012
    Etobicoke
    I'll have to read up on this, any good links for videos etc on changing those fluids?
    I bit the bullet and bought the TWM full replacement shifter anyways, but it probably won't hurt to put in the new fluids too
    Nov 2011
    Hamilton/St. Kitts
    Daaaamn, thanks dude prolly gonna get some soon then.. I also feel the 1st to 2nd shift is hard to make smooth but I've never experienced any grinding noise just a bit of jerking
    Member Elusivellama's Avatar
    Feb 2010
    2010 MS3 (black mica)
    9 Post(s)
    Quote Originally Posted by Sappo569 View Post
    Be warned, you will hear your differential when the car is cold and you're making a tight turn at low speeds. It's not an issue and I believe you shouldn't add friction modifier to make that noise go away (something to do about the friction modifier causing problems for the synchros). Others add the FM anyway, reasoning that it's just 6oz of fluid, and they don't have issues either.
    Nov 2009
    Montreal :(
    18 Post(s)
    lol too late
    Sr Member rzapata's Avatar
    Jan 2011
    Downtown TO
    36 Post(s)
    I did a combination of CP-E 75D RMM, JBR SSP + SSB, Ford tranny fluid, JBR heavy knob and that 1st to 2nd complication went away. Everything is a lot smoother now, haven't heard that annoying grind for months since I first had this combo. Although, it did make the shifting a bit stiffer due to the SSP. Nothing to be worried about though.
    Good combination altogether.
    EDIT:
    SSP = Short Shift Plate
    SSB = Solid Shifter Bushing
    Apr 2012
    Etobicoke
    So many acronyms...
    I'm hoping just replacing the whole dang thing with the TWM one eliminates the problem...
    129 Post(s)
    its not $250, unless the dealer were to order the fluid from ford not sure what it costs, the manual trans fluid replacements are around $150, auto is $189
    Barrie
    How come so much? Is it synthetic MTF? It's just as quick and easy as an oil change...
    Aug 2009
    16 Post(s)
    I was quoted somewhere around $89 less TM3 discounts at maple mazda to drain and fill with my own ford unicorn tears tranny fluid
    then again, jimmy did it for me last time around... pretty sure he was about half of that
    Member Turok's Avatar
    Apr 2009
    Woodbridge
    I'd get Jimmy to do it, he'll give you a good price.
    2001 Mazda P5 Black - Sold
    2005 Mazda 3 GT Black - Sold
    2007 MS3 Cosmic Blue Mica
    Cobb SF SRI - Cobb AP - Cobb TIH - CP-E TMIC - CP-E HPFP - CP-E DP - CP-E RMM(65A) - JBR TMM(80A) - Forge BPV - EGR Delete - SM OCC - Ford Full Synthetic MT Fluid - 225/40/18 Hankook Ventus V12's - TWM STS + bushings - 8000K HID Fogs - KY + Eibach Prokit Springs - JBR RSB - Rhoplate - Blue LED Interior lights - Black Weathertech liners - Blue SICKSPEED Horns - Blackvue DR400GHD
    TBI: Thermal TB and Intake Gasket
  1. 3rd to 2nd downshift grind after SSP install
    By fywdyl in forum MazdaSpeed 3 Forum
    Last Post: 03-23-2011, 11:08 PM
  2. Replies: 8
    Last Post: 01-11-2011, 11:43 PM
  3. Most Amazing Rail Grind ever!
    By iconicrocket in forum General Lounge
    Last Post: 03-29-2010, 10:10 PM
  4. 1-2 Shift Grind - Can't Solve
    By woaface in forum Problems with the Mazda3
    Last Post: 10-08-2008, 01:41 PM
