Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: Rattling at rear window
    27 Post(s)
    Default Rattling at rear window
    Just wondering if anyone else is having issues with rattling at the rear window were the plastic is? mine started about a month ago and it's driving me nuts. I was thinking of taking it apart to put some dymate to hopefully stop it from rattling unless someone else has a better solution.
    The rattle is coming from these plastic pieces
    ​A lion would never cheat on his wife, but a Tiger Wood.
    Newbie Sparcas's Avatar
    Jul 2007
    Default Re: Rattling at rear window
    I have an identical random noise in the back window - i haven't been able to determine what's causing it...
    I'll probably have to end up tearing out the whole back window portion to find a loose clip or seat-belt ....
    Good luck - hopefully someone will post something more constructive, other than "yeah i'm experiencing this too."
    2007 Mazda3 GT 2.3L / Fujita F5 CAI / KYB GR-2 Struts / LED Interior lighting / 8000K HIDs - 3000K Fogs / RAZO / 30% Lumar Ceramic Tint / LED 3rd Brake Light
    27 Post(s)
    Lol.... I'll take mine a part soon and see what's going on... Hopefully I find it
    Jul 2007
    If you take yours apart first - would surely appreciate any pics. The only thing I'd be afraid of is finding nothing out of place...... Pack it all with newspaper/dynamat.
    Sep 2012
    what the heck is that rattling, i wanna fix it. It starts randomly, sometimes it does it sometimes it doesnt
    Sep 2011
    Ottawa
    I encountered the same problem when I installed my stereo, the plastic cowl thing rattling/vibrating whenever I get a particularly deep base hit.
    I haven't done this yet, so I cannot comment on the efficacy, but someone on the forum here, or on OMC, suggested that I take the cowl off and line the edges with weather stripping from Home Depot.
    It should, in theory, stop the plastic from rattling against the window / other plastic trim.
    Member MarkWB's Avatar
    Apr 2012
    Everywhere (GTA)
    The White Pony
    Are your OEM jack and tire iron properly secured? What about the bolts and plate for your spare tire? Any of those could be loose and jiggling around producing a rattling noise.
    Got a variety of OEM Mazda 3 parts that need to go, thread coming soon, PM me for details!
    129 Post(s)
    Quote Originally Posted by MarkWB View Post
    good point, could be noise from other items unless there is someone back there that can hear it from that side / location. make sure theres nothing in the car or under seats making noise or making noise in the trunk as well.
    Sep 2011
    Ottawa
    I almost forgot, definitely check out the white plastic cover on the light in the trunk. That damn thing was causing about 70% of the rattle noise I was hearing from my trunk.
    Member mikey32235's Avatar
    Jul 2012
    for me i hear like a squeaking noise i have no idea what it is. the spoiler isn't rattling, it feels strong. i have my subwoofers in the trunk but they aren't touching anything. anyone have the same problem,?
    27 Post(s)
    Quote Originally Posted by mikey32235 View Post
    It my be the trunk hinges.... Spray some lube on the hinges and it should solve the problem.
    Jul 2012
    like white silicone grease? okk ill try it out and let u know, thanks!
    27 Post(s)
    I used the Krown lube...
    Jr Member goodcase's Avatar
    Sep 2010
    Burlington
    7 Post(s)
    I dont know if you drive a sedan or hatch. But i was having some rattling and deduced that it was coming from my spoiler mounting bolt. I drive a hatch.
    2010 Mazda 3 Sport GS:
    Mazdaspeed 3 Axle Back/ Eibach Pro-Kits / Koni STR.T / K&N SRI
    6000k HID / LED Interior Lighting Kit / Gun Metal RX8 Rims / Bridgestone Potenza RE760 225/40/18
    Jul 2012
    yea mines a hatch too... i thought it would b the spoiler. but when i shook the spoiler it wouldn't move its really sturdy. when u tightened the bolt did it go away?
    Sep 2010
    Burlington
    7 Post(s)
    Ya, but my spoiler had noticeable movement when I shook it. It might not hurt to check and see if they're tight though.
    Jul 2012
    yea its coming from the spoiler. how did u fix ur problem?
    Sep 2010
    Burlington
    7 Post(s)
    Just tightened down the mounting bolt for the spoiler. If you open the hatch, on the top left and right of the door you'll see two black plugs. Just take those off and the nut is right underneath them. You'll need a ratchet extension to reach them.
    Oct 2011
    I have the same issue. I tightened the bolts and the noise is still there. I know, its annoying the sh!t out of me too!
    Jul 2012
    what fixed MY problem was right when u open the hatch, look straight, there is a long black cover. remove it and your good to go lol.
    Newbie sammifan's Avatar
    Jul 2007
    Montreal
    I have a hatch, and fixed my rattling problem a long time ago by opening trunk and stuffing some foam under the cover that meets up with the back window. Rattling wasn't bad until I installed my rear motor mount.
    Cobb/CPE/HKS/Forge/Advan/Project Kics/Eibach/Koni/JBR/Rally Armor/Parts Plaza/DDM
    129 Post(s)
    Quote Originally Posted by sammifan View Post
    yup. my gfs 2010 rattled at the cover too. we put some foam tape there. noise gone.
    Costco = good cheap solution
    It's like a buck a nut
    Newbie kilo4321's Avatar
    May 2012
    Barrie, Ontario
    Noticed it happens for the first while while the car is cold, then when she warms up it disappears. Also comes from front window too sounds like cracking??
    U Mad Bro?
    Jr Member JrCanuck's Avatar
    Dec 2012
    Beamsville, Ontario
    45 Post(s)
    My spoiler rattles with my subs, but i just tightened it down.
    Now there's a constant rattle when i'm driving coming from up front, any ideas? I've already cleaned out my glovebox and tightened everything in my dash.
    Jul 2007
    Montreal
    Front rattling has been linked to the cowl below the wipers. Happens often when it's cold. There is a TSB for this for the gen 1s not sure about gen 2s.
  1. Rattling clunking noise from rear?
    By bluemazda3 in forum Problems with the Mazda3
    Last Post: 06-13-2011, 10:01 PM
  2. Annoying rattling sound rear top of car
    By rage2021 in forum Problems with the Mazda3
    Last Post: 04-23-2011, 09:13 PM
  3. Loud Rattling Rear Doors
    By RetroLite in forum I.C.E (In-Car Entertainment)
    Last Post: 06-29-2010, 11:06 AM
  4. Rattling glove box + Window Ratling
    By philipfreire in forum Frequently Asked Questions
    Last Post: 02-27-2010, 11:31 AM
  5. Rear strut rattling noise
    By CanSpeed 3 in forum Suspension & Brakes
    Last Post: 06-04-2008, 10:33 PM
