Results 1 to 2 of 2
Thread: When to change: Transmission Fluid, Steering Fluid, Brake Fluid?
    Nov 2006
    Question When to change: Transmission Fluid, Steering Fluid, Brake Fluid?
    My 2010 Mazda3 is at 47k (32 months).
    Other then regular oil change every 4-months, air filter and brake serviced (clean/lube), nothing else was done.
    Looking at my Schedule2 maintenance chart... it only says to inspect Steering & Brake fluid.
    When's the recommended KM/time for Transmission Fluid, Steering Fluid and Brake Fluid change? Thinking about it for my next service.
    Thanks!
    May 2012
    1997 Honda Civic SI
    Default Re: When to change: Transmission Fluid, Steering Fluid, Brake Fluid?
    Quote Originally Posted by GSXi View Post
    Thanks!
    The automatic transmission fluid gets dirty at around 50,000 km depending on your driving condition. You can check by the colour of the fluid by pulling out the dipstick. As for brake fluid, it is recommended to be flushed every two years or you can have it tested using a hydrometer.
  1. Replies: 14
    Last Post: 09-09-2011, 01:40 PM
  2. Replies: 14
    Last Post: 03-16-2010, 02:52 PM
  3. How often do you change brake fluid?
    By lancesir in forum Suspension & Brakes
    Last Post: 07-22-2009, 05:07 PM
  4. hey guys when do you change your manual tranmission oils ? - brake fluid?
    By phoenix_bladen in forum Mazda3 General Discussion
    Last Post: 07-15-2009, 12:11 AM
  5. Transmission Fluid change
    By Touge Tuning in forum General Lounge
    Last Post: 10-05-2006, 03:19 PM
