Page 1 of 3 123 LastLast
Results 1 to 25 of 69
Thread: Emission Testing changing 2013 to OBDII only
    Dec 2009
    Default Emission Testing changing 2013 to OBDII only
    Just curious as to what gains to this would be as the computer only test will benefit those with one cat delete option, Egr delete etc. I know you will be able to have one parameter out of the 4 in the self check area of the OBDII missing but any more is a fail and a check engine light is a fail and if computer is reset you wont have any parameters until the OBDII does the self checks and stores the related codes.
    If any even years are in need of a test next year get it done before Dec 31st but after your b-day and e-test will be good for 1yr and buy 2 yr sticker.
    Sr Member The Wolf's Avatar
    Aug 2010
    Slaughterloo
    Peugeot SS
    69 Post(s)
    Default Re: Emission Testing changing 2013 to OBDII only
    There will also be a "visual examination" where the mechanic will visually check for modifications such as cat and egr delete. They will also scan for piggyback systems or sims that "hide" CEL codes. Any of either will result in an automatic fail.
    Also, apparently if you clear a CEL right before the test, that shows up in their testing as "monitor not ready". If this happens, the testers have to drive your car long enough to reset the monitors... which will likely result in the codes being thrown again.
    Make no mistake, the only reason they are making a change to the emissions testing is to make more cars fail.
    Edit: Link - http://www.aa1car.com/library/ic10224.htm
    NO CREW
    CelestSpeed3's Avatar
    Aug 2005
    Vaughan
    48 Post(s)
    The real reason they are making the change is because shops no longer want to support the old E-test machines. Most SMS lost money on the older machines which is why most dealers don't have one. It required a huge investment which never paid off. This new test will allow even the smallest shops to get a piece of the pie. Not to mention because most dealers didn't have an e-test machine if you had to get emissions components replaced under warranty they could deny I and say that the test wasn't performed at a dealer. Since most emissions equipment is under warranty for 8 years and 160,000km there is no real reason to anyone to fail and have to pay out. Not to mention now the first time your car needs it's test is after 7 years not 5 like before.
    These tests are also harder to cheat. You can't get another car to run in place of yours unless you swap ECU's.
    Want to work on your car but not sure how, send me a PM. Learn the way of Nator.
    Apr 2012
    So what does mean for the ODB1 cars?
    Sponsor
    Lockdown's Avatar
    Oct 2011
    5 Post(s)
    This is interesting.
    I wonder how this will work with vehicles that use work arounds.
    The AccessPORT is nice but it doesn't do what a lot of other programmers do for other vehicles.
    For my mustang, there are quite a few options that are available which can perform, mimic or trick the OBD II port and ecu
    With cars with 4 cats, 4 O2s, it's generally accepted to turn off the rear.
    I was able to make my car pass this summer by simply swapping over some exhaust parts and retuning the car.
    I was able to get the required readings without issue but know a lot of people who couldn't even do that and had to swap back everything from heads forward and backwards.
    I guess no one knows but I'm curious to know if this will be able to tell what sensors we turn on and off.
    Anything I don't use, I turn off and remove.
    Phone: 647-439-4485
    AUDIO | SECURITY | ACCESSORIES | HID & LED LIGHTING | VIDEO & MULTIMEDIA | ELECTRICAL DIAGNOSIS
    Sponsor
    Lockdown's Avatar
    Oct 2011
    5 Post(s)
    OBD 1, likely won't have a huge issue. It's almost impossible to fail as is.
    Newbie Polish_Eagle's Avatar
    Mar 2008
    Waterloo, ON
    ZX-6R
    5 Post(s)
    Quote Originally Posted by Lockdown View Post
    The testing via OBD is for 1999+ OBDII vehicles only. Vehicles with OBDI or none at all will do a 2 stage idle test with the exhaust sniffer. They do the typical idle RPM and then rev it up to 2000 and do another reading.
    Member mikey32235's Avatar
    Jul 2012
    yep we got our machine ( not installed yet) at my canadian tire.
    Sr Member dentinger's Avatar
    May 2007
    Edmonton, AB
    12 Post(s)
    Glad I don't have to deal with this. No etests out here!
    I guess I should also rename the Engine/Drivetrain section "Arts & Crafts"
    2007 Mazda3 gx
    2003 Volkswagen GTI 20th Anniversary Edition
    2010 Kawasaki Ninja 250R
    2011 Dodge Ram 1500 Outdoorsman / 2012 Ducati Monster 796
    Jun 2011
    Ottawa
    This is why my car is staying mod free
    -- Black Mica Mazdaspeed 3 --
    STOCK FTW ... well because warranty
    123 Post(s)
    Quote Originally Posted by Polish_Eagle View Post
    similar to the diesel testing. will be interesting to see what happens. so the first test now every 7 years and then every other year the follows?
    Costco = good cheap solution
    It's like a buck a nut
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    It's easy to pass the new emissions testing machine coming to Ontario. NY state has been using this system for the past 15 years and my neighbour at my cottage has been fooling the system for years.
    123 Post(s)
    ok. and how do you do it?
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Top secret. I don't give out secrets to people who work for Mazda.
    Jr Member horto's Avatar
    Aug 2009
    16 Post(s)
    Hack the planet!
    Mar 2008
    79 Post(s)
    Quote Originally Posted by captobvious75 View Post
    That's no fun.
    I guess I should fix my 02 sensor before the next test.
    123 Post(s)
    .. ok.. not like we will be doing etesting any time in the near future.
    Jul 2008
    Subaru WRX
    265 Post(s)
    pwned
    123 Post(s)
    Quote Originally Posted by Thrizzl3 View Post
    pwned
    what ever you say phil...
    Apr 2012
    So the current system of putting the car on a dyno for an etest is going to be obsolete for pre 99 cars?
    Jun 2011
    Ottawa
    Quote Originally Posted by Dave_The_BMXER View Post
    That's no fun.
    Blame government
    Member fywdyl's Avatar
    Why is this in the ms3 section?
    that's what she said...
    Moderator loki's Avatar
    870 Post(s)
    don't know
    Jr Member rajin929's Avatar
    Nov 2007
    12 Post(s)
    BS money grab from the gov't.
    as much as i'd love a tuner import...just one more reason for me to go muscle car (i'm sure there's probably something in place to get those off the road too lol)
    2007 Mazda 3 GS sedan - Arctic White / Tan cloth
    Apr 2012
    Quote Originally Posted by rajin929 View Post
    That's the smart way to go. Go vintage if you want to mod. I learnt that the hard way.
  1. Emission's Test Result's
    By Effin Itai in forum Mazda3 General Discussion
    Last Post: 01-22-2013, 06:04 PM
  2. AllPro OBDII adapter, cut edition
    By sas in forum How-To Guides & Reference
    Last Post: 03-07-2010, 04:01 AM
  3. Headers Vs Emission testing
    By rcd001 in forum Performance
    Last Post: 06-13-2007, 10:08 AM
