Results 1 to 14 of 14
Thread: Dome Light no turning on when unlocking and opening doors
    Jr Member gar_lei's Avatar
    Jan 2009
    Montreal
    Default Dome Light no turning on when unlocking and opening doors
    Hello
    Recently I realize my dome light doesn't turn on when I unlock doors, open doors and remove key when shutting down.
    Also I feel like my turbo timer doesn't sense my door opening and closing because after I take the key out and close the door, my turbo timer doesn't start doing the count down even after a few mins so I had to shut down the car manually.
    Any clues if it's door sensor being faulty or a fuse?
    Thanks in advance
    - 2011 Crystal White Pearl Mazdaspeed 3 -
    - Street Tuned by MSpeed (Fobio) - Cobb SF SRI - Cobb TIH - Cobb DP - Denso ITV22 - Forge V2 BPV - Tanabe Strutbar - Buddy Club Voltage Condenser - Saikou-Michi OCC - Autotech HPFP Internals - CPe TMIC - CPe Stage 2 RMM - Redline Hood QuickLift Elite - Defi BF Gauges - Innovate DB Wideband Gauge - James Barone SSP+Bushing - ARC Titanium Shift Knob - Hawk HP+ - Stoptech SS lines - Swift Spec R Springs - Whiteline Rear Swaybar - Volk Racing RE30 18x8.5 - Project Kics R40 Neo Chrome -
    Jan 2009
    Montreal
    Default Re: Dome Light no turning on when unlocking and opening doors
    btw, I checked and my turbo timer is working cause when I open and close my trunk it kicks in the count down.
    Sr Member silverstarmazda's Avatar
    Dec 2011
    scar-BRUH
    97 Post(s)
    it might be something in the door. when i had my driver side door stuck unlocked, the lights wouldnt work unless pressed on them.
    50 shades of silver
    Jan 2009
    Montreal
    Ya my lights works when i press on them or when i turn the switch to ON.
    Dec 2011
    scar-BRUH
    97 Post(s)
    wait is it your dome lights(back) or your map lights? (front) or both.
    129 Post(s)
    you have a turbo timer installed in a 2011? i thought those didnt work? or is it only the models with the push buttons they dont work in? if they work when pressed it wouldnt be the fuse..hmmm
    Costco = good cheap solution
    It's like a buck a nut
    Jan 2009
    Montreal
    Both lights not turning on when i open door. But when i push or switch them to ON they work.
    Yes i have TT on 2011 without PTS
    129 Post(s)
    are the switches on the right position? do they work from the slider if you turn that to on?
    Jan 2009
    Montreal
    yes they're in door position.
    Jan 2009
    Montreal
    Anyone?
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    Quote Originally Posted by gar_lei View Post
    Anyone?
    Take it to the dealership.
    Sr Member Noisy Crow's Avatar
    Did you check all of the doors, or just the driver's door?
    BTW, odds are high that the turbo timer has two input triggers... one for the trunk, and one for the dome light. Trunk is probably a pin switch. (but might be a tap into the "trunk is open" wire.) Dome light is probably a tap into the wire running to the dome light. Likely the installer used ScotchLok taps.... which if installed improperly damage the wire. Very likely if check the tap you find the wire has broken (wire insulation may be more or less intact, with the copper conductor broken)
    129 Post(s)
    agree. not anything common to guess at over the web. have someone look at it.
    Dec 2009
    Hard to say over here as Booter mentioned but if all your doors do not trigger the dome lights to come on it would be a bigger problem than just a door sensor in the drivers door. Possibly would be a module that controls these features. look up in the shop manuals see what you can find. Best bet is warranty at dealership!
