Results 1 to 7 of 7
Thread: Rear Shock Install BC Coilovers/Stock Upper Shock Mounts
    Newbie MDMaz3's Avatar
    Oct 2011
    Default Rear Shock Install BC Coilovers/Stock Upper Shock Mounts
    I bought a set of used BC Coilovers but only noticed afterwards I wasn't sold the original upper rear shock plates that came with them. Can I reuse the upper stock ones ? Does anyone have any experience with this?
    I can order from BC if necessary but am hoping stockers will do the trick.
    KYB'S AND PROKITS, MS REAR SWAY,RX8's
    Member standsideways's Avatar
    Jan 2010
    5 Post(s)
    Ide reuse them if the rubber isn't all cracked and chewed,they will definitely be more comfy than the solid aluminum ones!
    Sponsor - GTA Retrofits
    Hyperion's Avatar
    252 Post(s)
    Default Re: Rear Shock Install BC Coilovers/Stock Upper Shock Mounts
    They should work fine.
    Oct 2011
    Quote Originally Posted by standsideways View Post
    I have the rubber bushings that come with the rear bc coil shocks. Solid aluminum ones? I'd assume the stocker and the BC Coil one are both aluminum, meaning the upper shock mount.
    Sr Member peterm15's Avatar
    Sep 2010
    Bradford
    143 Post(s)
    I can't really remember if i did but If you can remove them from the old shocks go for it.
    BTW I'm pretty sure he's talkin about shock mount. The one that is bolted to the car with 2 10mm nuts.
    Oct 2011
    Thanks guys, you just saved me $112 plus shipping from FLA where BC Racing is located!!! Much appreciated. You gents are awesome.
    Was thinking to get to Street Performance to get these and my rsb installed. The mech will have no issues then.
    Jan 2010
    5 Post(s)
    See the rubber im talking about...
  1. Replies: 44
    Last Post: 12-19-2014, 10:28 PM
  2. rear right shock going on my car
    By jaimie08mazda3 in forum Suspension & Brakes
    Last Post: 01-17-2009, 01:19 PM
  3. mazda3 recall RE: oil pipe, door plate, and shock sensor .... No more shock sensor?
    By JaYson in forum Known Issues, Technical Service Bulletins (TSB's), & Recalls
    Last Post: 08-06-2008, 01:30 PM
