Results 1 to 3 of 3
Thread: idle and running rattle
    Jr Member proDJtege's Avatar
    Oct 2012
    Vaughan
    Default idle and running rattle
    So I recently was working in the engine bay installing a set of grounding wires and the big3 wires.
    While running an alternator wire underneath the intake, it contacted metal and shorted against something.
    Could that have fried the Intake Manifold electricals?
    I ask because now I have an idle and running rattle similar to in this video..
    and
    It sounds like it's coming from the belt area, but I could be wrong.
    Immediately after my mods, I didn't notice this, but about a day later, I did notice the rattle. As the engine is faster on the highway, the rattle speeds up and eventually gone.
    Thoughts?
    ProDJtege //
    gone: Black 2002 Protege LX 2.0L [LEDs, modified intake, P5 side-skirts & OEM front lip]
    gone: Black 2008.5 GT 2.3L, mostly stock + LEDs + K&N filter + black painted calipers & hubs + Hawk HPS brake pads + synthetic 5w20 oil + STB + Flex 5-wire ground kit + Flex Big3 kit + 23% NR-charcoal tint
    Current: 2017 Dark Grey Subaru Forester 2.5i Ltd w/ tech + 23% NR Charcoal tint
    Oct 2012
    Vaughan
    Default Re: idle and running rattle
    no thoughts? Bueller?
    Member Genpu_Mz3's Avatar
    Aug 2012
    G-Spot
    68 Post(s)
    do you still get power on that plug? check it, if you don't, obvious course of action is to check the fuses, but if you do, i'd say you have something more serious going on, you should take it in.
  1. Rattle! Help
    By Mzdablkout in forum I.C.E (In-Car Entertainment)
    Last Post: 12-20-2011, 07:47 PM
  2. Death rattle in '05 2.3L... HELP!
    By gnashings in forum Engine & Drivetrain
    Last Post: 03-21-2010, 10:27 PM
  3. Sub in truck, rattle
    By matt9 in forum I.C.E (In-Car Entertainment)
    Last Post: 10-07-2009, 04:17 PM
  4. Does it rattle??
    By _naz in forum Lighting, Electrical & Security
    Last Post: 11-03-2005, 11:43 PM
  5. A little rattle....
    By Xenon in forum Problems with the Mazda3
    Last Post: 08-22-2005, 01:57 PM
