MODS: I posted this here because I didn't think fit any one particular area in the Technical section
Hello all,
This weekend I am (with some, ok..probably a lot of help) installing a laundry list of items on my car.
The purpose of this post is to call on others experience to help me spot any gaps in my parts list to make sure I'll have everything I need.
I'll be listing here all the parts I HAVE (some will be kinda obvious, but I wanted to be thorough)
Brakes:
Pads
Rotors
Duplicolor Caliper Painting Kit
Brake pad grease
Rear Sway Bar:
MS3 Bar
MS3 OEM Bushings
MZ3 OEM brackets
Moog MS3 Endlinks (part # K750069)
Exhaust:
HKS exhaust
Vibrant 2.5" gaskets (3)
Spin on filter conversion (For oil temp and oil pressure gauges):
2.0L Oil filter mount
2.0L filter mount bolts
Filter mount gasket
Mishimoto sandwhich plate (part # MMOP-TPS)
Oil pressure sender
Oil temp sender
K&N spin on filter
Water temp sensor:
Water temp sender mount (30mm, installing in upper rad hose)
Water temp sender
Spark plugs
NGK Iridium IX
Rally Armor flaps rear (fronts already installed):
Rear flaps
U-bolts (4)
Moutning screws/bolts
Stuff I still need to get
18 or 24 gauge wire (to wire senders to gauges in my car)
O-rings for ends of wires (to attach to grounding point, anyone know the size of the grounding point bolts in the engine?)
Shrink tube
Wire conduit (to protect wires coming from the oil senders in engine bay)
Thread tape that is oil resistant (to wrap threads of senders before I put them in the sandwhich plate)
Urethane/Plastic spacer for bottom hole of rear rally armor flaps
Bracket for spacer
U-bolts (I need 4 more)
Bushing grease
Loctite 425 (Blue) for endlink bolts
Spark plug gapping tool
New brushes for caliper paint
Please let me know if you spot any gaps in my parts list, or if you have any recommendations.
Thanks!
