Results 1 to 25 of 30
Thread: Peter's logs
    Sr Member Peter's Avatar
    Feb 2011
    36 Post(s)
    Default Peter's logs
    Well here they are , lets hope they work.
    Engine Mod list
    Top Mount intake system (ram Air)
    FMIC
    Forge V2 recirc valve
    Auto Tech Internails
    Cpe Rmm
    JBR transmission mount
    Cp-e Down Pipe with hight flow cat
    secondary cat and muffler delete custom 2 inch exhaust
    Attached Files Attached Files
    Jr Member mickey_g's Avatar
    Apr 2012
    Mississauga, ON
    44 Post(s)
    Default Re: Peter's logs
    @Peter you may want to trim the logs...we just need your WOT log
    May 2012
    53 Post(s)
    HOLY LONG LOGS BATMAN!!! Trim that lol...
    As Mickey said, we just need the point where you go from 2500rpm to +6000rpm (redline is possible). Boost needs to be full, Traction control off and the pedal position needs to be floored in 3rd or 4th gear.
    Feb 2011
    36 Post(s)
    Well atleast I know how to upload now lol. Hey makes a good read lol. Ill do another rip after my shift. Hopefully something by tonight.
    295 Post(s)
    Took a skim but we need cleaner logs.
    Looks weak TBH.
    Member Scottobot's Avatar
    Apr 2008
    Orangeville
    From the title of this thread I expected something completely different.
    Feb 2011
    36 Post(s)
    Quote Originally Posted by Scottobot View Post
    Gotta admit was thinking of someone else to make that comment
    MajesticBlueNTO's Avatar
    May 2004
    49 Post(s)
    Trimmed the logs for the only WOT parts that were useful.
    looking at 220ish whp and 245ish wtq
    Feb 2011
    36 Post(s)
    Quote Originally Posted by MajesticBlueNTO View Post
    Thanks for the trim. But that can't be right. I went to streetpower last year all I had was the intake with tubo inlet and forge recirc valve I got 242whp. How can I be less now. Maybe something really is wrong. I'll find the print out and post it up tonight.
    Member fywdyl's Avatar
    Still need to take into account the weight and other factors.
    However, OTS maps are super conservative, so it is quite possible that you lost HP. Looks like with the increased loads, you are now running way less timing than before.
    P.S. - looks like you need a MAF calibration as well.
    that's what she said...
    Feb 2011
    36 Post(s)
    Cool makes sense. How do I do the calibration
    May 2004
    49 Post(s)
    get proper logs in 3rd gear from ~2500 to 6500 rpm. take a 4th gear log if you make it to a closed road in mexico.
    if you put those trimmed logs in -->Virtual Dyno<-- using the 2nd and 3rd gear ratios from this site for the Gen2 ... selecting DynoJet and Smoothing 3 and guessing the occupant weight at 140 lbs, you get the power and torque listed
    Feb 2011
    36 Post(s)
    [QUOTE=MajesticBlueNTO;1131795]get proper logs in 3rd gear from ~2500 to 6500 rpm. take a 4th gear log if you make it to a closed road in mexico.
    Awesome thanks ill do my best.
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    [QUOTE=Peter;1131799]
    Save yourself the bull shit and get mspeed to tune you. Knowing your driving record you will hit something.
    Jul 2008
    Subaru WRX
    265 Post(s)
    What an ass lol. But it's true
    Feb 2011
    36 Post(s)
    [QUOTE=Fack_Dude;1131817]
    What are you talking about my driving records clean lol. Everyone else is the moron. .
    I'm going to. Not going I get into personal stuff. But I can fin ally get it done. Just need to set up a day.
    May 2012
    53 Post(s)
    Got FWIW and @Peter, this is what a 4th gear WOT log is.
    Apr 2012
    Mississauga, ON
    44 Post(s)
    @Peter before even getting a tune, need to make sure that your car is healthy...I would make a trip to Jimmy (or someone else you trust) to go over the car make sure everything looks good
    Newbie MarineMazda's Avatar
    Mar 2012
    Barrie
    Mazdaspeed6
    13 Post(s)
    Quote Originally Posted by mickey_g View Post
    If you hang out with some of the NATOR guys and such we can teach you how to make sure your car is healthy. Get involved in the community and you save money! That being said if you want to learn how to do a compression check and go over everything the offer is open. I can show you how it's done but you will be doing it.
    We really need a WOT log, I would also like to see a MAF cal log as well, judging from those ones you need a MAF cal pretty bad.
    Feb 2011
    36 Post(s)
    Quote Originally Posted by MarineMazda View Post
    @MarineMazda thanks for the offer, ill get on it as soon as i can. @pwdunmore has met up with me and showed me a few things so hopfully at least get the calibration done right soon.
    Sponsor
    BlueStreak's Avatar
    Oct 2007
    34 Post(s)
    Am I reading the original post correctly? Custom 2" exhaust?
    From where? The downpipe-back? Stock piping is 2.5".
    Larger piping is always better in a turbocharged car. Air needs to come in fast (intake-turbo-intercooler-throttle body-intake manifold) and leave fast (exhaust manifold-downpipe-cat back).
    Putting a 2" exhaust on the speed is like trying to run 400m as fast as you can while breathing through a straw. No bueno.
    May 2012
    53 Post(s)
    It's a 2.5'', he didn't type it out right, he basically had his muffler and resonator deleted plus got all the aluminized piping replaced with some nice steel.
    When looking at his logs, he was just rich as hell and needed a closed loop MAF cal for the time. He was gonna do that then I was gonna probably help him with the WOT calibrations and WGDC to get him hitting boost consistently.
    If he does him homework I can probably help him setup a hybrid OTS map (load capped) that will stop him from overboosting in the winter, since the cobb OTS ones suck nuts for cold weather.
    Sponsor
    BlueStreak's Avatar
    Oct 2007
    34 Post(s)
    Ok.
    I thought it was a typo as well but then saw 2" exhaust mentioned in his car thread.
    Feb 2011
    36 Post(s)
    Ok.
    It's 2.5 I type way too fast and keep forgetting my bad. Shooting to get this tune done by the end of this month. Been pulling crazy hours at work to finally get this done.
    Feb 2011
    36 Post(s)
    So this happened lastnight going home. Now this morning. Having trouble starting it. Finally have I started. Been running on, for 20min now.
  1. Peter 's Speed 3
    By Peter in forum Member Rides
    Last Post: 05-07-2014, 11:55 PM
  2. Happy Birthday Peter!
    By Mazdy in forum General Lounge
    Last Post: 04-30-2012, 10:18 AM
  3. Hangin' Out at St. Peter's
    By k-existence in forum General Lounge
    Last Post: 12-07-2009, 10:52 PM
  4. You know Peter Chao?!
    By Fobio in forum Pictures and Videos
    Last Post: 09-15-2009, 12:37 AM
