Results 1 to 13 of 13
Thread: subs in 2014 3
    Jan 2014
    Question subs in 2014 3
    hey guys
    has anyone installed subs in the new 2014 mazda 3 with the new touch system
    ive been trying to find some information on it and cant seem to get any.
    thanks in advance
    Jr Member goodcase's Avatar
    Sep 2010
    Burlington
    7 Post(s)
    Default Re: subs in 2014 3
    Quote Originally Posted by 3abuser View Post
    hey guys
    thanks in advance
    It's such a new vehicle that you might have to be a guinea pig and be the first to figure it out.
    2010 Mazda 3 Sport GS:
    Mazdaspeed 3 Axle Back/ Eibach Pro-Kits / Koni STR.T / K&N SRI
    6000k HID / LED Interior Lighting Kit / Gun Metal RX8 Rims / Bridgestone Potenza RE760 225/40/18
    Jan 2014
    yeah thats what im thinking hoping there is an amp that connects to the speakers
    sashaytag jaimie08mazda3's Avatar
    Oct 2007
    Guelph
    207 Post(s)
    2 Thread(s)
    LOC is always one way to do it. I dunno if they have a wiring harness for the 2014 but I bet it would be a pain in the ass to remove. Then again I thought that about my 08 and turned out it was take out the dash piece and remove 2 screws so ya never know.
    They say I'm an addict but I don't have a problem with alcohol or drugs. I'm an addict because I can't live without bass. Car audio is my addiction. And it will never change.
    Jr Member DLYDRVN's Avatar
    May 2013
    Toronto/Kitchener
    2009 Speed3, Yoz. Mazda2
    110 Post(s)
    if i had to make a guess the wiring harness adaptor is probably identical to the most recent models. Just a guess of course, but I'd be willing to place $10 on it being the same metra harness as previous gen models.
    Performance COBB AP v3 (345whp/360wtq) - CS Puppy Power Turbo - HTP 3" Widepath - Turbosmart BPV - CS TMIC - Cobb 3-Port - Teflon TIG - CS Catch Can - Autotech Internals - UR 3" Turboback Exhaust - ACT 6-Puck Ceramic Clutch Kit - Filled TMM - CPe RMM - JBR Short shifter - CS Short Shift Plate - Shifter Bushings - CS Front Big Brake Callipers - StopTech Sport 309 Pads - CS FSB - CS RSB - Bilstein B14 PSS Coilovers - CS Mid-Brace - Defi Gauges - CS Steering Wheel - FAST Underground 18x8 - BFG gForce Sport comp2 235/45r18
    Sound & Appearance Kenwood eXcelon DNX893s - JL C3-570 - JL 10W6v2 sub - JL XD400/4 - JL XD600/1 - Kinetik 600 Power Cell - 2AWG Big 3 - Redline Boots - CS LED Fogs - CS Lic. Plate Kit
    Member gabbygenier's Avatar
    Ottawa
    20 Post(s)
    if you do a quick search on the metra and sosche sites (2 main manufacturers for harnesses and dash kits) there is nothing right now for the 2014's
    adding subs wouldnt be too hard though. as mentionned already, a simple LOC (line out converter) would help you out with that. many different options for those out there.
    found this thread about a LOC.
    http://mazda3revolution.com/forums/2...p-upgrade.html
    2004 mazda 3 GT Sedan Indigo Blue.
    May 2016
    Hey I have talked to few car audio tech. They all seem to mention the same thing. It requires a special harness kit or some sort. As the factory head unit does not have rca or audio inputs. They said it's positive to install without voiding warranty and cutting lines and wires. I will have mine amp and sub installed two-week from now cost 260 plus tax hope this helps
    393 Post(s)
    You likely need a line out converter. Can be had cheap, but even a good one is less than $50.
  9. The Following User Says Thank You to S.F.W. For This Useful Post:
    jaimie08mazda3 (05-05-2016)
  10. #9
    Oct 2007
    Guelph
    207 Post(s)
    2 Thread(s)
    This. Basically what a Line Output converter does is take the signal from the left and right door speaker and converts them to the Left and right RCA as the stock decks do not have RCA hookups. When I used to run one back 6 years ago or so, they were the left and right positive and negative wires and the RCAs on the other side. Now these things have your remote wire hookups, power, ground and even bass knobs. Amazing how much things change in a short time.
  11. #10
    Dec 2006
    hey guys
    thanks in advance
    If it's a GT with Bose, it make things more complicated...
    [SIGPIC][/SIGPIC]
  12. #11
    Oct 2007
    Guelph
    207 Post(s)
    2 Thread(s)
    Quote Originally Posted by Sebi View Post
    Not really. It would still be the same way with a Line Output Converter. If you did a deck too then yea it would be.
  13. #12
    Aug 2011
    Hey...I'm in the process of doing this now. Just need to make a custom box for the trunk. No need to cut the factory harness. I bought this harness off ebay. Plug and play.
    http://m.ebay.com/itm/Mazda-3-2003-P...163?nav=SEARCH
    http://www.ebay.com/itm/291516818046...%3AMEBIDX%3AIT
  14. #13
    Mar 2016
    I have 2 12" subs tied to a JL Audio 1000 watt amp in my 2015 Mazda 3. Peel Audio did the install for me last summer. Good bass and I have never had any problems with Peel Audio's work in this matter. I have the touch screen option too. I am thinking of selling the setup as I keep pulling the subs out of the back as I am using the hatch to carry more stuff now and I am getting sick of doing this twice a week.
  1. 2014 Mazda6 or 2014 Accord Sport Sedan
    By sudz in forum Other Cars
    Last Post: 05-01-2014, 05:38 PM
  2. Replies: 29
    Last Post: 08-01-2013, 01:25 AM
