Results 1 to 25 of 44
Thread: How-to: Upgrade 2004-2009 Mazda 3 windshield washer nozzles to wide fan spray nozzles
    Default How-to: Upgrade 2004-2009 Mazda 3 windshield washer nozzles to wide fan spray nozzles
    I recently became the primary driver of our 2008.5 Mazda 3 (was my wife's car previously, she now drives the new CX-5), and after a horrible winter constantly cleaning road splatter off the windshield, I discovered I hate the OEM wiper nozzles on the 3. The CX-5 has nozzles that shoot a fan-shaped spray of washer fluid all over the window, so I decided to look into replacing mine.
    I know there are aftermarket kits out there that have the fan spray, but the bottom of the nozzle (where the hose connects) on those ones points straight down. The 2004-2009 Mazda 3 has a 90 degree bend in the nozzle bottom, so the hose connects from the side. If you use one of the nozzles that point straight down, you would need a few bits-and-bobs to connect the hoses. I read one thread (somewhere, not sure which forum) where someone recommended cutting holes in the under-hood insulation layer where the hoses attach to the bottom of the nozzle, so that nothing kinks afterwards.
    To simplify the process and keep things as clean under there as possible, I decided to look for a fan-spray nozzle with a 90 degree bend in the bottom part facing the same direction as the Mazda 3's. I finally found one: the 2008-2012 Ford Fusion nozzle is virtually identical to the 2004-2009 Mazda 3 one, except it has the fan-shaped spray pattern.
    I bought them through the local Ford dealership for about $10 each.
    The steps to replace the nozzles:
    To access the washer nozzles from the underside of the hood, you must remove some of the retainer clips holding the under-hood insulation layer to the hood. I just removed the circled ones first, then changed that nozzle, then re-attached this half of the insulation layer with the clips, then repeated the process with the other side. In other words, I never removed the insulation layer entirely, just took enough clips off half of it to reach that side's nozzle, then re-attached the insulation layer and repeated the process on the other side.
    To remove the retainer clips, you can use a special tool that's made for it, like these:
    But I just used a hammer:
    It worked fine. Some of the clips will possibly break, but in removing 10, I only broke 1. You can re-use the ones that don't break. To replace the one that broke, I found a new one at PartSource for $1.
    Once you have the insulation layer out of your way, you can reach the underside of the washer nozzle, where the hose connects. Disconnect the hose. You may have to work at it, twisting a bit and using your fingernail... It's on there tight...
    The nozzle is held on with tabs you squeeze to allow it to pop up through the hole...
    I used pliers, but you may be able to do it with your fingers...
    Then pull the nozzle off the rest of the way from the top... Please ignore my dirty car...
    This is the shape of the hole. Clean the area around the hole before installing the new nozzle, just to make sure there's no dirt or grit under the new nozzle where it contacts the hood.
    And this is the new nozzle installed. Perfect fit! Just pop it in and reconnect the hose underneath, then re-attach the under-hood insulation, and do it all over again for the other nozzle.
    Here is a video of the two spray patterns, the Ford Fusion one on the left, and the original Mazda 3 one on the right.
    I hope this is useful to somebody out there. In my searching, I couldn't find anyone referencing the 2008-2012 Ford Fusion nozzles as a direct replacement for the 2004-2009 Mazda 3 nozzles. I just discovered it by doing an image search for windshield washer nozzles, and looking for one that looked similar to the Mazda one, then trying to discover what the spray pattern of it was like. Even that was a crapshoot since I couldn't find any discussion of the spray pattern of the Fusion nozzle. At first I just bought the one to make sure the spray was a fan-type. I installed it and discovered it was exactly what I wanted, so went and bought the other one. They were about $10 each at the Ford dealership.
  2. The Following 14 Users Say Thank You to Yasmar For This Useful Post:
    DualSoul (05-27-2014),FMJ (04-22-2015),geobur (05-19-2015),greyseason (08-26-2014),jswift79 (01-14-2015),k13 (05-08-2015),Katievn (08-26-2014),Mazduh (01-07-2016),Noobster12 (04-18-2015),npausuav (06-08-2016),peteselva (10-15-2016),roachkillah (11-24-2014),ryan2.3 (04-04-2014),Scottobot (04-17-2015)
  3. #2
    Moderator Mr Wilson's Avatar
    Jan 2010
    227 Post(s)
    Default Re: How-to: Upgrade 2004-2009 Mazda 3 windshield washer nozzles to wide fan spray noz
    Great write-up!
    0.000212524463 gigawatts
  4. The Following 2 Users Say Thank You to Mr Wilson For This Useful Post:
    geobur (05-19-2015),Yasmar (04-04-2014)
  5. #3
    Member ryan2.3's Avatar
    Nov 2011
    Roseville, MI
    '91 318i, '11 550i
    86 Post(s)
    if anyone is thinking of doing this, i'd like to buy your 4 nozzle sprayers. I actually like them, and wanted to put a set in another car because the two nozzle ones are garbage.
  6. #4
    Jr Member proDJtege's Avatar
    Oct 2012
    Vaughan
    This looks like a really good idea, considering the performance of our stock nozzles.
    can anything be done about the hatch rear window nozzle pattern?
    ProDJtege //
    gone: Black 2002 Protege LX 2.0L [LEDs, modified intake, P5 side-skirts & OEM front lip]
    gone: Black 2008.5 GT 2.3L, mostly stock + LEDs + K&N filter + black painted calipers & hubs + Hawk HPS brake pads + synthetic 5w20 oil + STB + Flex 5-wire ground kit + Flex Big3 kit + 23% NR-charcoal tint
    Current: 2017 Dark Grey Subaru Forester 2.5i Ltd w/ tech + 23% NR Charcoal tint
  7. #5
    Quote Originally Posted by ryan2.3 View Post
    If you PM me your address, I'll mail you my old ones free. I don't need them...
  8. #6
    Quote Originally Posted by proDJtege View Post
    I haven't found anything online about the rear window nozzle being fixable or upgrade-able. I wish, though... It's pretty lousy...
  9. #7
    Nov 2011
    Roseville, MI
    '91 318i, '11 550i
    86 Post(s)
    The rear is sad, it's like a drippy faucet.
    Also pm'd
  10. #8
    Oops...
    After replying to you that you could have my old nozzles, I went looking for them and now I think I must have thrown them out. Can't find them anywhere. Sorry, man...
    My new Ford Fusion ones only cost me ten bucks each, so if you really like the 4 jet Mazda nozzles you could check the price at a Mazda dealer and purchase them directly if no one else here responds to offer you theirs.
  11. #9
    Sr Member RedRaptor's Avatar
    Jul 2004
    9 Post(s)
    Thank you for the write up. I've always liked the fan spray on our Ford Windstar back in the day. I'll be looking to do this in the summer time.
    2004 Mazda3 Sport GT|Winning Blue| OG 2.3L @ 450,000 km & counting
  12. #10
    Mar 2008
    79 Post(s)
    This is awesome.
  13. #11
    Jr Member hex's Avatar
    Markham, ON
    35 Post(s)
    OP, does the ford fusion nozzles spray above the windshield? that's what the video looks like. i would 100% do this, but i'd prefer my windshield washer fluid on my windshield and not on top of my car
  14. #12
    2012 Porsche 911
    133 Post(s)
    Looks like it sprays a fine mist. I wonder what that would be like in -25 degree weather.
  15. #13
    Quote Originally Posted by hex View Post
    I'm not sure. I haven't done it and then checked to see if my roof is wet. Will try it tomorrow to let you know... FWIW if any goes on top of the car, it can't be too much because the windows do get pretty soaked...
  16. #14
    Quote Originally Posted by Jackal View Post
    I did the swap after the worst of our winter was past, so I can't answer that for you... I'm sure it'll be fine, though, as I've had other cars with similar spray and they were good in the winter too.
  17. The Following User Says Thank You to Yasmar For This Useful Post:
    Jackal (04-06-2014)
  18. #15
    Here is a video and pics to show the new spray pattern and lack of overspray with both nozzles now changed to the Ford Fusion ones.
    Pics:
    The paper towel at the top is completely dry. Even the one just at the top of the windshield is mostly dry. The saturation is right where it is most effective. Works great!
    With the top two layers of paper towel removed, so you can more easily see the coverage in relation to the windshield...
  19. The Following 5 Users Say Thank You to Yasmar For This Useful Post:
    FMJ (04-22-2015),hex (04-09-2014),k13 (05-08-2015),ryan2.3 (04-22-2015),vip3r87 (04-08-2014)
  20. #16
    Jr Member vip3r87's Avatar
    Jan 2010
    Oakville
    Quote Originally Posted by Yasmar View Post
    Pics:
    I hope that was no-name brand stuff...haha
    great write-up man might have to do this myself. That or I may switch to the nozzles that are attached to the wiper blades themselves.
  21. #17
    Jr Member Souls's Avatar
    Apr 2010
    Holodeck 12
    WOW, now that's how it's done, great write up. sticky
  22. #18
    Markham, ON
    35 Post(s)
    Pics:
    Holy shit, a simple yes or no would've been good enough! Thanks though! I'll probably be doing this.
  23. #19
    untz untz untz soccerboy1491's Avatar
    Aug 2011
    53 Post(s)
    I def wanna do this too now lol. I hate the one on our cars, thanks!
  24. #20
    Newbie ziegs2020's Avatar
    Apr 2008
    Nice upgrade. I always wondered what the wiper blades would do if you left them up and ran the switch.
  25. #21
    Jr Member DLYDRVN's Avatar
    May 2013
    Toronto/Kitchener
    2009 Speed3, Yoz. Mazda2
    110 Post(s)
    This won't work for the 09 speeds tho will it? our jets aren't in the hood. So much sad...
    Performance COBB AP v3 (345whp/360wtq) - CS Puppy Power Turbo - HTP 3" Widepath - Turbosmart BPV - CS TMIC - Cobb 3-Port - Teflon TIG - CS Catch Can - Autotech Internals - UR 3" Turboback Exhaust - ACT 6-Puck Ceramic Clutch Kit - Filled TMM - CPe RMM - JBR Short shifter - CS Short Shift Plate - Shifter Bushings - CS Front Big Brake Callipers - StopTech Sport 309 Pads - CS FSB - CS RSB - Bilstein B14 PSS Coilovers - CS Mid-Brace - Defi Gauges - CS Steering Wheel - FAST Underground 18x8 - BFG gForce Sport comp2 235/45r18
    Sound & Appearance Kenwood eXcelon DNX893s - JL C3-570 - JL 10W6v2 sub - JL XD400/4 - JL XD600/1 - Kinetik 600 Power Cell - 2AWG Big 3 - Redline Boots - CS LED Fogs - CS Lic. Plate Kit
  26. #22
    Aug 2014
    Excellent write up! My 07 was an easy switch, 60 seconds tops to get it on. Pulled back the insulator pad, didn't have to remove any retainer caps, popped in the new one and it worked like a charm. $9.48+tax at a local Ford.
  27. #23
    Apr 2012
    Any idea if this works on the 2014 models as well?
    2012 Mazda 3 Skyactiv
  28. #24
    Nov 2014
    Great write-up, I absolutely HATE the original nozzles on my 05!
    Do the Ford ones perform well while highway driving? The stock ones barely wet the bottom 1/3 of the windshield when I'm going 100+ and it's really annoying, feels like I have to squirt half a gallon of fluid to get the whole windshield clean.
  29. #25
    Feb 2012
    awesome write up, i'm going to do this on my 08.
    thanks.
  1. Replacing Washer Nozzles on 2008 Mazda 3
    By walltico in forum Problems with the Mazda3
    Last Post: 01-04-2013, 09:16 AM
  2. Replacing Washer Nozzles on 2008 Mazda 3
    By walltico in forum Mazda3 General Discussion
    Last Post: 12-30-2012, 06:06 PM
  3. Replacing Washer Nozzles on 2008 Mazda 3
    By walltico in forum Exterior & Interior Maintenance
    Last Post: 12-30-2012, 04:56 PM
  4. Adjusting windshield washer nozzles
    By WeatherB in forum MazdaSpeed 3 Forum
    Last Post: 08-10-2008, 05:33 PM
