Results 1 to 8 of 8
Thread: MAF Calibration on ots intake specific maps
    Noob Astromax's Avatar
    May 2014
    Sudbury ON
    Default MAF Calibration on ots intake specific maps
    Sorry if this is a noob question, been looking through threads on tm3 and msf for an hour already without finding an answer.
    I have the corksport sri+tip on my speed. I just got the v3 accessport and applied the corksport stage 1+sri ots map. Is it still required to scale the entire map due to difference in housing size over stock? Or would the intake specific map already have that scaling done and only require tweaking each breakpoint set based on my datalogs?
    Of the top of my head my first good log reading was showing approximately -12.5, -7.6, -5.4, -1.6.
    287 Post(s)
    Default Re: MAF Calibration on ots intake specific maps
    The OTS maps are a starting point and have a rough calibration. However every MAF sensor (and o2 sensor, etc) is a little different which leads to slight variations intake to intake, car to car, and hence the need for a MAF calibration.
    If you have LTFT's that aren't within +/- 3 or so, you should be doing a round or two of MAF calibration. If those -12.5, -7.6, -5.4, -1.6 are your LTFT values, you definitely need to do a calibration.
    May 2014
    Sudbury ON
    So should I still start by scaling the entire map by 1.313 (3" corksport vs stock) then adjusting each breakpoint set?
    287 Post(s)
    Exactly which intake do you have?
    Exactly which map are you using?
    Give us links to both...it's kind of important.
    Banned
    Apr 2010
    Projects
    another mazda
    51 Post(s)
    In for HIB
    May 2014
    Sudbury ON
    287 Post(s)
    Ok so you don't have the 3" intake, you have a normal stock sized MAF housing intake. There is no scaling necessary, just do a MAF cal.
    May 2014
    Sudbury ON
    Alright sounds good, thanks for the help
  1. 19 AFR at Idle with JBR intake (even after MAF Calibration)
    By pwdunmore in forum MazdaSpeed3 Tuning
    Last Post: 10-21-2012, 06:57 PM
  2. JBR Intake MAF Cal and Map
    By pwdunmore in forum MazdaSpeed3 DISI General Powertrain
    Last Post: 10-04-2012, 12:55 PM
  3. MAF calibration question
    By Elusivellama in forum MazdaSpeed3 Tuning
    Last Post: 03-26-2012, 02:00 PM
  4. Need help with Intake MAF
    By Spoolin in forum MazdaSpeed 3 Forum
    Last Post: 03-24-2011, 01:40 PM
  5. Official Cobb 1.03 OTS Maps
    By Fobio in forum MazdaSpeed3 Modifications
    Last Post: 03-16-2009, 03:13 PM
