Results 1 to 8 of 8
Thread: Crasth logs
    Jr Member crasth's Avatar
    Mar 2014
    54 Post(s)
    Default Crasth logs
    Hey guys so ive had some issues with power after my cs sri installation and havent been able to fix, i have a thread in msf forum so if u have time to go and give ur input that would.be awesome.
    http://www.mazdaspeedforums.org/foru...d.php?t=174809
    2010 CWP ms3
    ENGINE
    -corksport stge 2 sri + tip,cpe hpfp,cobb ap,turbosmart BOV 50/50,jbr boost tubes,bpv hose
    SUSPENSION
    -H&R lowering springs, koni yellow shocks
    Sr Member optiklenz13's Avatar
    Jun 2009
    Jeep Wrangler
    126 Post(s)
    Default Re: Crasth logs
    @loki .. Move to http://www.torontomazda3.ca/forum/fo...aSpeed3-Tuning
    @crasth which map are you running and list your mods..
    Instagram : optiklenz13 / focalpointconcepts
    www.optiklenz13.com
    FPC10
    Mar 2014
    54 Post(s)
    Quote Originally Posted by optiklenz13 View Post
    Cs sri+tih, cs rmm, cs stage one 91 map sri +tih
    286 Post(s)
    I doubt anyone here has any additional insight to that of MSF...or at least, you should have started a real thread here.
    Member fywdyl's Avatar
    What happens if you flash the stock map? Do you still get low boost targets?
    that's what she said...
    Mar 2014
    54 Post(s)
    Still the same. I dont know what is going on. Do u think a maf cal will fix that?
    Quote Originally Posted by crasth View Post
    Did you do a leak test like they told you to on MSF?
    If you haven't done it yet, try doing a MAF cal, if the MAF cal is unsuccessful (like you can't get within +/- 4 LTFT) then it could be hardware issue.
    Did you break the nipple on the TIP when installing it? Are any of the hoses kinked or ripped?
    Also post logs here too.
    Mar 2014
    54 Post(s)
    hey guys so now that im able to attach logs i wanna continue this thread and try to get some help from you guys, people at msf have been helpfull but i kinda feel more comfortable posting here as this is the forum i read more. so ive had the boost issue for quite some time and havent figured out the roots of it. i thought it was a boost leak but i took it to jimmy and he said he checked it and there was none. he said compression test came out well too (170-175 avg) now the problem im facing is i dont hit boost targets, back when the weather was warmer i was only getting peak of high 14s in 3rd gear. now that weather is colder im hitting 15s. this is really confusing me as i dont know why this is happening. i know in colder temps is easier to make boost but iunno why i was boosting lower in around 15 degrees which is not too hot to affect boost. ill post some logs so if anyone want to check out and help itll be much appreciated. im running stage 1 cs sri+tih map( upped the wg by 5%)
    datalog13 was taken at 5 degrees and it seems like im close to my boost targets.
    datalog 11 was taken on slightly warmer weather and you can see the diff.
    i took few logs just to make sure the issue is consistent. now that there is no leak i dont know where should i start looking at
    Attached Files Attached Files
  1. paulabreu's logs
    By paulabreu in forum MazdaSpeed3 Tuning
    Last Post: 10-08-2014, 11:26 PM
  2. My Logs
    By Booostin in forum MazdaSpeed3 Tuning
    Last Post: 10-17-2012, 02:16 PM
  3. *My logs/ V dyno's*
    By standsideways in forum MazdaSpeed3 Tuning
    Last Post: 06-30-2012, 05:25 PM
  4. Marinemazda's Logs and VD's
    By MarineMazda in forum MazdaSpeed3 Tuning
    Last Post: 04-03-2012, 12:48 AM
  5. Some DH logs
    By TriniFyah7 in forum MazdaSpeed3 Tuning
    Last Post: 10-14-2011, 02:22 PM
