Cab0oze
Yeah I'm a big fan of Tremclad due to the low cost, how durable it is and how easy it goes on. You can get it at canadian tire. I used Fire Red for the calipers and black for the hubs. If you want to paint the calipers fancy colors go to the paint section, there is tons of aerosol caliper paint too, just requires more effort to mask things off before spraying whereas with brush on you don't have to do that really.
Re: the wood block, I presume you're talking about the rotor and not the caliper. And the answer is yes, when I actually planned on saving the rotor.
New calipers are pricey, don't replace them unless you have to lol. I actually had mine rebuilt, but that is pretty expensive too.
No, I would just get whatever rotors are cheapest but still a reputable brand name. OEM brake stuff isn't made by mazda, it is made by a supplier and rebranded. For example, my calipers are clearly branded as ATe. I'm not sure who makes mazda's rotors, but rotors are all pretty much the same. Centric premium blanks are usually what people recommend. I'm not sure who makes mazda pads, but brake pads are a different story - different pad materials make a huge difference so don't want to risk getting one that isn't exactly what you want. I would recommend going with OEM pads, which is what you said you were doing, so good choice there.
